Hi
I am trying to set up a simple simulation as a practice for a larger more complex simulation. I am attempting to move a body downward (-z direction) at a constant velocity, then apply a constant acceleration, So when I use the motion command I need to input the the initial displacement and velocity. I know I could just put in -250 in for the initial displacement but I am trying to have a 'smart system' as this object will be interacting with a powder using EDEM co simulation, and I wont know the initial displacement of the body. I am trying to use DZ function but its not working, when the motion command is used the body jumps back to its starting position, as if I had entered '0' for ic_disp
my script is below, if I enter -250 for ic_disp it work as I want, B_0 is the body being move, and is the only body
<Simulate
analysis_type = 'Transient'
end_time = '5'
print_interval = '0.01'
<Motion_Joint
id = '301001'
joint_id = '301001'
motion_type = 'T'
val_type = 'A'
ic_disp = 'DZ({b_0.cm.idstring},{Global_Frame.idstring})'
ic_vel = '-50'
type = 'EXPRESSION'
expr = '10'
<Simulate
end_time = '15'
