I have evaluated experiment result value of system identified(using Java), human identified result(manual), true positive, true negative, false positive and false negative values for my 3 models(ie 3 methods).
using this result I want to identify which model gives the best result in statistical analysis.
(i don't know about statistical analysis, rapid miner, R, and I know only java)
so pls give the solution for this
