Hi all,
can somebody explain me why the Replace (Dictionary) operator suffixes the replacements with indexes?
I want to map to following values that are loaded from an Excel file and I checked that they are read in correctly:
| from attribute |
to attribute |
None |
| J1 |
Early |
| J2 |
Early |
| J1-2 |
Early |
| J3 |
Late |
| J2-3 |
Late |
| J4 |
Late |
| J3-4 |
Late |
| J5 |
Late |
| J4-5 |
Late |
Late |
I have selected single attribute and set it to the attribute containing the above from attribute-values. The from attribute property is set equal to 'from attribute' and the to attribute property is set to 'to attribute'. Since this concerns a class label I checked include special attributes.
Now, Rapidminer creates the following values:
None, Early, Early-1, Early-2, Late, Late-4,Late-5,J2,J3,J5 (why doens't it replace J2, J3 & J5 ???).
What I expect this operator to do is that it creates only 3 values: None, Early and Late
If I wanted the suffixes I would have added them myself, but to my knowlegde there is no way to stop it from doing this.
Is this an option that needs to be turned off? Or how I can I achieve this replacement without resorting to manual entry in some operator like the Map-operator?
Best regards,
Wouter
