30.6.2017
Colleagues:
Just updated to RM Studio 7.5.3 (from 7.5.1) and see that there is an issue with the Tableau Table Writer (writes Tableau Extracts) - it no longer shows up in my extensions and processes that use this operator have a red square on the canvas where the operator used to be - and all inputs and output connections to this operator no longer exist. Tried installing the extension multiple times from the Marketplace, all seems to proceed fine, but when RM Studio re-starts post the install, the Tableau Table Writer extension is not in my list of extensions. The path to the Tableau extract API is still in my environment variables as it should be, the Tableau Extract is still installed where originally installed.
I went to https://docs.rapidminer.com/studio/how-to/data-export/tableau.html and clicked on the "Install Table Writer in Studio" button and received a message saying that this operator is already installed and up to date. Looks like some sort of configuration metadata issue perhaps? Perhaps I need to manually update a RM Studio configuration file?
Attached to this post are 3 screen shots - two views of my "Extensions" directory and a list of installed extensions (from "Manage Extensions" menu option).
Is the Tableau Table Writer extension compatible with RM Studio 7.5.3? If not, is there a way I can revert to 7.5.1 for the time being? I'd be grateful for any suggestions in resolving this issue. Best wishes, Michael Martin
