I'm trying to create a ranking for examples (rows) in a data set. This ranking should be relative to the other examples (rows) in the dataset.
I did the following:
1) Set roles for the ID and label attribute ("Set Role" feature)
2) Discretized the examples by binning ("Dicretize by Binning" feature)
3) Generated weights for each example ("Generate Weight (Stratification)")
Am I on the right track?
