Hi...I'm noticing that the new decision tree graphics are actually harder to read than the old. Is there something I can change?
and the description is cut off as well...
Do you have the latest version of the extension installed? I have it in mine.
Hey Scott,
for the description you an use Decision Tree to Example Set from Converters extension. It essentially uses the same code.
~Martin
Thanks @mschmitz. Unfortunately I don't see Decision Tree Model to Example Set in the Converters extension. Am I missing something?
Scott
No I did not. Thanks, Tom.
