Hi everybody, when I read the help of hyperwork, for example in /INTER/TYPE7 there are some ones like that
= 0:default, set to value defined in /DEFAULT/INTER/TYPE7
But when I open /DEFAULT/INTER/TYPE7 everything is blank. So where can I find the default value or it is =0?
Thank you for reading.
