problems installing on headless Ubuntu 164
User: "kayman"
New Altair Community Member
Updated by Jocelyn
Getting nuts trying to install on a headless machine using putty.
I think I followed the instructions as on this page pretty well : https://docs.rapidminer.com/server/installation/headless_install.html
My XML seems ok, is called installer.xml and is placed in the same bin folder
when I try to run the following command (I am in the bin folder)
...my_rapid_download/bin$ sudo ./rapidminer-server-installer installer.xml
I get an error stating sudo: ./rapidminer-server-installer: command not found
While it is clearly there.
I've tried a whole lot of variations, but nothing seems to work. Any idea what I am doing wrong here ?
1 - 1 of 11
    User: "homburg"
    Accepted Answer
    most likely the cause for this issue is a lack of permissions. When i.e. no execute permission is given sudo returns a 'command not found' error. You may try to run
    sudo chmod 755 rapidminer-server-installer
    and execute the installation command again.
    Cheers,
    Helge
