Colleagues: Being relatively new to the RM Platform I've been happily experimenting with various techniques. I created a model that uses Stacking, which worked great until I added a SVM to the Stacking Operator (either as part of the "Model Stack" or as the "Learner". Now the process throws an error just before completion and stops. The log error messages (all of them severe) and the Excel source data for the process are contained in the attached file "Error_Messages_and_Source_Data.zip" which can be inflated with either WinZip or WinRar.
The Process I designed is in the attached .rmp file.
When I take the SVM out of the Stacking operator and replacing it with another Operator (such as Deep Learning, etc.) everything works great again - so I am led to the conclusion that either one should simply not use a SVM as part of a Stacking Model, or there is another step that needs to be done given the requirements / architecture of the SVM Operator within a Stacking Model.
Thanks for considering this and pointing me in the right direction and best wishes, Michael
