Hello .
I want to implement genetic programming in Rapid Miner, but I do not know what operator I use?
and how do implement parallel in radoop?
please guide me
There are several genetic programming type operators in RapidMiner Studio. For example, there is the Optimize Generation (YAGGA) and (YAGGA2) operators. Then there is the Optimize Parameters or Selection (Evolutionary). Just look search for YAG or Evol in the parameters to find them all.
With respect to using them in Radoop, you will need to put them inside a SparkRM operator first.
Thank you very much for the quick response.
You said to use radoop,
I've sparkRM, but it is in the form of red markson it.
What is the reason? How to solve it?
Thank you for your guidance.I saw your educational videos.Do you have educational videos you've trained genetic programming?If the link you please show me. Thanks
I don't think we do.
