I have a small dataset with around 12 rows and with timeseries - values for each month. What are the parameters that I need to change when using a windowing operator so that I can forecast for more than a month? Since the dataset is small I used Window size as 1, step size as 1 and horizon as 1. Please suggest.
Thank you,
Pavan
Please see: http://community.rapidminer.com/t5/RapidMiner-Studio-Knowledge-Base/How-to-Use-Annotations-to-Attach-Performances-and-Timestamps-to/ta-p/35961
on how to use Annotations.
