Timeseries model - Changing windowing parameters to forecast more than 1 month
pavan_gundala
New Altair Community Member
I have a small dataset with around 12 rows and with timeseries - values for each month. What are the parameters that I need to change when using a windowing operator so that I can forecast for more than a month? Since the dataset is small I used Window size as 1, step size as 1 and horizon as 1. Please suggest.
Thank you,
Pavan
Why is this in the Developers Forum? Should this not be in the RapidMiner Studio Forum?
0 -
My bad...I moved it..thanks !!
0 -
Did you read this post: http://community.rapidminer.com/t5/RapidMiner-Studio-Forum/Financial-Time-Series-Prediction/m-p/33456
There is a process that let's you generate 't+n' into the future to predict your time series.
