I have created a RM process whose first operator is "Process Documents from Files" with its text directory parameter pointing to a directory which contains all the input files eg :/home/sample/RM/input/
The process works fine and takes all the files under the above location as input.
Now my requirement has changed a bit and I want to give all the file as inputs in the request body of the Webservice exposed for the process.
So I have exposed the Process as Web service through RM server. I want to do a post call to the service with body of the request having the actual files.
