🎉Community Raffle - Win $25
Join and Win
If then statement
User: "diellasingh"
New Altair Community Member
Updated by Jocelyn
I am trying to write an "if then" statement to generate an attribute. I would like to replace the ".0" in the attribute "partNOconcat" with "" (Nothing).
For example: partNOconcat : AA10000.0AA
i would like to replace it to give me in my new attribute the following; newGenAtt: AA10000AA
I currently have the following as my expresion:
if(partNOConcat contains(partNoConcat,".0"),replace(partNoConcat,".0",""))
This gives me the following error: "Syntax Error (implicit mulitplication not enabled)"
Please could someone provide me with some guidence to where I am going wrong.
Thank you,
Diella
1 - 1 of 11
    User: "diellasingh"
    OP
    Accepted Answer
    Hi Thomas,
    Thank you for your fast response time. I didn’t know that was possible to autopopulate a process from XML.
    About the syntax provided. I am not retrieving the desired output. I’m struggle to construct the third argument. Whereby I would like the value of the generated attribute (dot_zero) to have the attribute value of the [temp] for that particulate example if ".0" is not found within the [temp] attribute value.
    Syntax: if(contains(".0",partNoConcat),replace(".0",partNoConcat,""),partNoConcat)
    Please could you tell if this is even possible with the If function expression in RM.
    Thanks,
    Diella
