Personally I tend to focus on feature selection first, since it is more concerned with dimensionality reduction and elimination of not-quite-necessary attributes. Several feature selection approaches are unsupervised and do not even require an inner learner (PCA, remove correlated attributes, etc). Even when you are using Forward Selection or Backward Elimination you could use an inner learner that does not require optimization, such as Naive Bayes.
Once I have a reduced set of attributes, then I tend to focus on the true modeling optimization. But I would say feature engineering (creating new attributes from the existing raw attributes) may be even more important to getting the best model than either feature selection or optimization, so don't neglect that either!
Hi Brian,
Thank you for your comment.
So far I thought of using the same learner within the optimizer as in the modelling. The idea of taking a naive bayes instead sounds interesting. Though I have to admit that I cannot imagine how this should work. (I should have mentioned that I am working on series modelling.) Nevertheless I will give it a try and hopefully get surprised
Thank you as well for sharing your experience on the importance of feature engineering. This seems to be a point which is not in the focus of most discussions. So I am going to pay more attention to this and rework my process accordingly.
Kind regards
Sachs
+1 on the comments on feature engineering! The impact of this is often much bigger than picking an uber-complex model or optimize its parameters to death in my opinion...
My personal approach is very iterative. I start finding any model which is somewhat better than guessing. As soon as I have this, I optimize its parameters a little bit. Then I spend most time in feature engineering. And in the end, I go back to model selection and parameter optimization. If this is still not good enough, I iterate over this multiple times with the main focus on the the feature engineering part.
If you want to go really fancy, you can try some of the automatic genetic-programming-inspired operators like YAGGA2 ;-)
Cheers,
Ingo
Thanks for all your helpful comments :smileyhappy:
