Dear all,
I would like to suggest a new feature to the "lag series" operator of the series extension. Currently this operator lags the selected attribute according to the specified parameter. However, the parameter has to be >= 1. So I was wondering why this is limited in that way. I would come handy if this operator could also lag negative values -> the other direction.
Best regards
Sachs
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.5.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="7.5.001" expanded="true" height="68" name="Generate Data" width="90" x="45" y="34"/>
<operator activated="true" class="series:lag_series" compatibility="7.4.000" expanded="true" height="82" name="Lag Series" width="90" x="179" y="34">
<list key="attributes">
<parameter key="att1" value="1"/>
</list>
<connect from_op="Generate Data" from_port="output" to_op="Lag Series" to_port="example set input"/>
<connect from_op="Lag Series" from_port="example set output" to_port="result 1"/>
</process>
</process>
