Reuse results of loop while removing attributes
Dear all,
Here is a feature proposal I would like to discuss with you: I just came across a process where I wanted to remove attributes within a loop. This could be done using "loop attributes" and "select attributes" as its nested operator.
However, I discovered that the loop will be carried out as many times as attributes were in the set at the beginning of the loop. In my case I remove attributes while looping and reuse the result. But still the loop goes over attributes which aren't there anymore after removal.
Feature proposal: Have the option to adapt loop iterations to existent attributes only when reuse of result is activated.
This sample code removes att2 in the first loop. However, in the console is shown that there are still three iterations for att1, att2, att3.
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.5.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="7.5.001" expanded="true" height="68" name="Generate Data" width="90" x="45" y="34">
<parameter key="number_examples" value="25"/>
<parameter key="number_of_attributes" value="3"/>
<operator activated="true" class="concurrency:loop_attributes" compatibility="7.5.001" expanded="true" height="82" name="Loop Attributes" width="90" x="179" y="34">
<parameter key="reuse_results" value="true"/>
<operator activated="true" class="select_attributes" compatibility="7.5.001" expanded="true" height="82" name="Select Attributes" width="90" x="45" y="34">
<parameter key="attribute_filter_type" value="regular_expression"/>
<parameter key="regular_expression" value="att2.*"/>
<parameter key="except_regular_expression" value="%{loop_attribute}"/>
<operator activated="true" class="print_to_console" compatibility="7.5.001" expanded="true" height="82" name="Print to Console" width="90" x="179" y="34">
<parameter key="log_value" value="%{loop_attribute}"/>
<connect from_port="input 1" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Print to Console" to_port="through 1"/>
<connect from_op="Print to Console" from_port="through 1" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<connect from_op="Generate Data" from_port="output" to_op="Loop Attributes" to_port="input 1"/>
<connect from_op="Loop Attributes" from_port="output 1" to_port="result 1"/>
</process>
</process>
Cheers
Sachs
Best Answer
Hi Sachs,
challenge accepted
I added a few Operators to your process and hope the result fits your needs.
The macro %{a} represents the actual number of executions this Operator has.
Best,
Edin
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="generate_data" compatibility="7.5.001" expanded="true" height="68" name="Generate Data" width="90" x="112" y="34">
<operator activated="true" class="series:windowing" compatibility="7.4.000" expanded="true" height="82" name="Windowing" width="90" x="246" y="34">
<parameter key="window_size" value="5"/>
<operator activated="true" class="generate_id" compatibility="7.5.001" expanded="true" height="82" name="Generate ID" width="90" x="112" y="136"/>
<operator activated="true" class="concurrency:loop_attributes" compatibility="7.5.001" expanded="true" height="82" name="Loop Attributes" width="90" x="246" y="136">
<operator activated="true" class="generate_macro" compatibility="7.5.001" expanded="true" height="82" name="Generate Macro" width="90" x="45" y="34">
<parameter key="expression" value="cut(%{loop_attribute},0,index(%{loop_attribute},"-"))"/>
</list>
<operator activated="true" class="select_attributes" compatibility="7.5.001" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34">
<parameter key="regular_expression" value="%{expression}.*"/>
<parameter key="use_except_expression" value="true"/>
<operator activated="true" class="select_attributes" compatibility="7.5.001" expanded="true" height="82" name="Select Attributes (2)" width="90" x="313" y="85">
<parameter key="attribute" value="%{loop_attribute}"/>
<operator activated="true" class="select_attributes" compatibility="7.5.001" expanded="true" height="82" name="Select Attributes (3)" width="90" x="447" y="136">
<operator activated="true" class="branch" compatibility="7.5.001" expanded="true" height="82" name="Branch" width="90" x="447" y="34">
<parameter key="condition_type" value="expression"/>
<parameter key="expression" value="%{a}==1"/>
<operator activated="true" class="remember" compatibility="7.5.001" expanded="true" height="68" name="Remember" width="90" x="45" y="34">
<parameter key="name" value="dataset"/>
<connect from_port="condition" to_op="Remember" to_port="store"/>
<portSpacing port="source_condition" spacing="0"/>
<portSpacing port="sink_input 1" spacing="0"/>
</process>
<operator activated="true" class="recall" compatibility="7.5.001" expanded="true" height="68" name="Recall" width="90" x="45" y="34">
<operator activated="true" class="join" compatibility="7.5.001" expanded="true" height="82" name="Join" width="90" x="179" y="85">
<parameter key="join_type" value="left"/>
<list key="key_attributes"/>
<operator activated="true" class="remember" compatibility="7.5.001" expanded="true" height="68" name="Remember (2)" width="90" x="313" y="34">
<connect from_port="condition" to_op="Join" to_port="right"/>
<connect from_op="Recall" from_port="result" to_op="Join" to_port="left"/>
<connect from_op="Join" from_port="join" to_op="Remember (2)" to_port="store"/>
<portSpacing port="source_condition" spacing="63"/>
</process>
<connect from_port="input 1" to_op="Generate Macro" to_port="through 1"/>
<connect from_op="Generate Macro" from_port="through 1" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Branch" to_port="condition"/>
<connect from_op="Select Attributes (2)" from_port="original" to_op="Select Attributes (3)" to_port="example set input"/>
<connect from_op="Select Attributes (3)" from_port="example set output" to_port="output 1"/>
</process>
<operator activated="true" class="recall" compatibility="7.5.001" expanded="true" height="68" name="Recall (2)" width="90" x="380" y="136">
<operator activated="true" class="select_attributes" compatibility="7.5.001" expanded="true" height="82" name="Select Attributes (4)" width="90" x="514" y="136">
<parameter key="attribute" value="id"/>
<connect from_op="Generate Data" from_port="output" to_op="Windowing" to_port="example set input"/>
<connect from_op="Windowing" from_port="example set output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Loop Attributes" to_port="input 1"/>
<connect from_op="Recall (2)" from_port="result" to_op="Select Attributes (4)" to_port="example set input"/>
<connect from_op="Select Attributes (4)" from_port="example set output" to_port="result 1"/>
</process>
</process>0
For those of you who want to know more on the background / use case:
Appearingly a simple question but in detail this one drove me mad: I am looking for a regular expression which takes a string out of a macro (e.g. "att1-a") as a reverence value.
All attribute names shall be selected that have the same prefix before the "-" (--> prefix = "att1") but NOT if the complete reverence value is identical to the attribute's name.
att1-a --> no match because list entry identical to reference
att1-b --> match because prefix is the same
att1-c --> match because prefix is the same
att2-a --> no match because prefix is different
att2-b --> no match because prefix is different
att2-c --> no match because prefix is differentI came close to the desired result but in the end the looping over already removed attributes lead to an empty set in the end.
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="series:windowing" compatibility="7.4.000" expanded="true" height="82" name="Windowing" width="90" x="179" y="34">
<operator activated="true" class="concurrency:loop_attributes" compatibility="7.5.001" expanded="true" height="82" name="Loop Attributes" width="90" x="313" y="34">
</list>
<connect from_op="Select Attributes" from_port="example set output" to_port="output 1"/>
</process>
<connect from_op="Windowing" from_port="example set output" to_op="Loop Attributes" to_port="input 1"/>
</process>
</process>0 -
Thanks for the idea! I've passed this onto the Developers!
0 -
Hi Sachs,
challenge accepted
Best,
Edin
<context>
<input/>
<output/>
<macros/>
</context>
</list>
</process>
</process>
</process>
</process>
</process>0 -
Hi Edin,
That's a pretty impressive piece of code! Congratulations!
Best regards
Sachs
