"Association Rules Renaming results"
stfn
stfn New Altair Community Member
Hello.
I am working on association rules. I want rules about courses every semester. It works fine but the thing is that i want to rename the results.
Capture.JPGFor example "321-8354" corresponds to course "Networks",  "321-8952" to "E-Management" etc...
Here is my code which does not work for "renaming" the results.
<?xml version="1.0" encoding="UTF-8"?><process version="7.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="jdbc_connectors:read_database" compatibility="7.4.000" expanded="true" height="68" name="Read Database" width="90" x="45" y="34">
<parameter key="connection" value="New connection1"/>
<parameter key="query" value="SELECT `lesson_id` AS Item, `status` AS Amount, `student_id` AS Id&#10;FROM `grades`&#10;WHERE `edate` BETWEEN '2016-01-15' AND '2016-02-28'"/>
<enumeration key="parameters"/>
<operator activated="true" class="replace" compatibility="7.4.000" expanded="true" height="82" name="Replace (1)" width="90" x="45" y="136">
<parameter key="attribute" value="Amount"/>
<parameter key="replace_what" value="Success"/>
<parameter key="replace_by" value="1"/>
<operator activated="true" class="replace" compatibility="7.4.000" expanded="true" height="82" name="Replace (3)" width="90" x="45" y="238">
<parameter key="replace_what" value="Fail"/>
<parameter key="replace_by" value="0"/>
<operator activated="true" class="parse_numbers" compatibility="7.4.000" expanded="true" height="82" name="Parse Numbers (3)" width="90" x="45" y="340">
<parameter key="grouped_digits" value="true"/>
<parameter key="unparsable_value_handling" value="replace with missing values"/>
<operator activated="true" class="aggregate" compatibility="7.4.000" expanded="true" height="82" name="Aggregate (2)" width="90" x="179" y="34">
<parameter key="use_default_aggregation" value="true"/>
<parameter key="attribute" value="Status"/>
<parameter key="default_aggregation_function" value="sum"/>
<parameter key="Amount" value="sum"/>
</list>
<parameter key="group_by_attributes" value="Id|Item"/>
<operator activated="true" class="pivot" compatibility="7.4.000" expanded="true" height="82" name="Pivot (2)" width="90" x="179" y="136">
<parameter key="group_attribute" value="Id"/>
<parameter key="index_attribute" value="Item"/>
<operator activated="true" class="rename_by_replacing" compatibility="7.4.000" expanded="true" height="82" name="Rename by Replacing" width="90" x="179" y="238">
<parameter key="replace_what" value="sum[-!&quot;#$%&amp;'()*+,./:;&lt;=&gt;?@\[\\\]_`{|}~]Amount[-!&quot;#$%&amp;'()*+,./:;&lt;=&gt;?@\[\\\]_`{|}~]_"/&gt;
<parameter key="replace_by" value=" "/>
<operator activated="true" class="numerical_to_binominal" compatibility="7.4.000" expanded="true" height="82" name="Numerical to Binominal" width="90" x="179" y="340"/>
<operator activated="true" class="set_role" compatibility="7.4.000" expanded="true" height="82" name="Set Role" width="90" x="313" y="34">
<parameter key="attribute_name" value="Id"/>
<operator activated="true" class="handle_exception" compatibility="7.4.000" expanded="true" height="82" name="Handle Exception" width="90" x="313" y="136">
<parameter key="exception_macro" value="exp"/>
<operator activated="true" class="concurrency:loop_attributes" compatibility="7.4.000" expanded="true" height="82" name="Loop Attributes" width="90" x="112" y="34">
<parameter key="attributes" value="Id"/>
<operator activated="true" class="rename" compatibility="7.4.000" expanded="true" height="82" name="Rename" width="90" x="313" y="34">
<parameter key="old_name" value="Id"/>
<parameter key="new_name" value="lesson id"/>
<list key="rename_additional_attributes">
<parameter key="321-8354" value="stefania"/>
<parameter key="321-1200" value="stefania2"/>
</list>
<connect from_port="input 1" to_op="Rename" to_port="example set input"/>
<connect from_op="Rename" from_port="example set output" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<connect from_port="in 1" to_op="Loop Attributes" to_port="input 1"/>
<connect from_op="Loop Attributes" from_port="output 1" to_port="out 1"/>
<portSpacing port="source_in 2" spacing="0"/>
</process>
<operator activated="false" class="print_to_console" compatibility="7.4.000" expanded="true" height="68" name="Print to Console" width="90" x="112" y="34">
<parameter key="log_value" value="%{exp}"/>
<connect from_port="in 1" to_port="out 1"/>
</process>
<operator activated="false" class="select" compatibility="7.4.000" expanded="true" height="68" name="Select" width="90" x="313" y="391"/>
<operator activated="true" class="fp_growth" compatibility="7.4.000" expanded="true" height="82" name="FP-Growth" width="90" x="447" y="34">
<parameter key="find_min_number_of_itemsets" value="false"/>
<parameter key="positive_value" value="true"/>
<parameter key="min_support" value="0.005"/>
<operator activated="true" class="create_association_rules" compatibility="7.4.000" expanded="true" height="82" name="Create Association Rules" width="90" x="447" y="238"/>
<operator activated="false" class="store" compatibility="7.4.000" expanded="true" height="68" name="Store" width="90" x="447" y="391">
<parameter key="repository_entry" value="../data/test1Data"/>
<operator activated="false" class="read_excel" compatibility="7.4.000" expanded="true" height="68" name="Read Excel" width="90" x="45" y="442">
<list key="annotations"/>
<list key="data_set_meta_data_information"/>
<connect from_op="Read Database" from_port="output" to_op="Replace (1)" to_port="example set input"/>
<connect from_op="Replace (1)" from_port="example set output" to_op="Replace (3)" to_port="example set input"/>
<connect from_op="Replace (3)" from_port="example set output" to_op="Parse Numbers (3)" to_port="example set input"/>
<connect from_op="Parse Numbers (3)" from_port="example set output" to_op="Aggregate (2)" to_port="example set input"/>
<connect from_op="Aggregate (2)" from_port="example set output" to_op="Pivot (2)" to_port="example set input"/>
<connect from_op="Pivot (2)" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/>
<connect from_op="Rename by Replacing" from_port="example set output" to_op="Numerical to Binominal" to_port="example set input"/>
<connect from_op="Numerical to Binominal" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Handle Exception" to_port="in 1"/>
<connect from_op="Handle Exception" from_port="out 1" to_op="FP-Growth" to_port="example set"/>
<connect from_op="FP-Growth" from_port="frequent sets" to_op="Create Association Rules" to_port="item sets"/>
<connect from_op="Create Association Rules" from_port="rules" to_port="result 1"/>
</process>
</process>
Any ideas how to fix this? I run out of ideas.
Thanks,
stfn
Best Answer
  • stfn
    Answer ✓
    Hello Thomas
    Yes it is almost the same but did not fingure how to do this so i made a different post.
    It didn't work =/
