Dear community,
As a part of a larger script I am trying to copy selected attribute columns to a new example set.
Source example set:
label att1 att2
1 a 1x
2 b 1y
3 c 1z
Target shall look like this (att2 copied from source):
att2
1x
1y
1z
My script looks currently like this:
import com.rapidminer.tools.Ontology;
exampleSet sourceTable = input[ 0 ];
exampleSet targetSet = new ExampleSet();
targetSet.addAttribute(sourceTable.getAttribute("att2"));
return targetSet;
Looking forward to any feedback...
PS: There are likely various ways to get from the original example set to the target one. But context of my whole script I am looking especially for a way to copy an attribute column.
PPS: By the way, is there any chance to access the values of macros in a script?
Best regards
Sachs
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.5.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="7.5.000" expanded="true" height="68" name="Generate Data" width="90" x="45" y="34"/>
<operator activated="true" class="execute_script" compatibility="7.5.000" expanded="true" height="82" name="Execute Script" width="90" x="179" y="34">
<parameter key="script" value="import com.rapidminer.tools.Ontology; exampleSet sourceTable = input[ 0 ]; exampleSet targetSet = new ExampleSet(); targetSet.addAttribute(sourceTable.getAttribute("att2")); return targetSet;"/>
<connect from_op="Generate Data" from_port="output" to_op="Execute Script" to_port="input 1"/>
<connect from_op="Execute Script" from_port="output 1" to_port="result 1"/>
</process>
</process>
