Combining values from common examples into new attributes
arsalan_karim
arsalan_karim New Altair Community Member
Hi All
I have the following list:
Drug ID     Drug Name     Ingredient
23              Centrum         Vitamin D
23              Centrum         Vitamin B
23             Centrum          Vitamin C
I need to convert this into:
Drug ID     Drug Name     Ingredient1           Ingredient 2            Ingredient 3
23              Centrum         Vitamin D               Vitamin B              Vitamin C
I have tried everything and playedaround and could not get an answer...
Help ??
Arsalan
Best Answer
  • MartinLiebig
    MartinLiebig
    Answer ✓
    Hey,
    you can go for Aggregate group_by Drug Name and concat(Ingridient), this gives you
    23              Centrum         Vitamin D|Vitamin B|VitaminC
    Afterwards you can use a Split operator to split the Ingredient on \| to get the desired output. Attached is the demo process.
    Best,
    Martin
    <?xml version="1.0" encoding="UTF-8"?><process version="7.3.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.3.001" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" breakpoints="after" class="subprocess" compatibility="7.3.001" expanded="true" height="82" name="Subprocess" width="90" x="45" y="85">
    <operator activated="true" class="generate_data_user_specification" compatibility="7.3.001" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="45" y="34">
    <list key="attribute_values">
    <parameter key="Drug ID" value="23"/>
    <parameter key="Drug Name" value="&quot;Centrum&quot;"/>
    <parameter key="Ingridient" value="&quot;Vitamin A&quot;"/>
    </list>
    <operator activated="true" class="generate_data_user_specification" compatibility="7.3.001" expanded="true" height="68" name="Generate Data by User Specification (2)" width="90" x="45" y="187">
    <parameter key="Ingridient" value="&quot;Vitamin B&quot;"/>
    </list>
    <operator activated="true" class="generate_data_user_specification" compatibility="7.3.001" expanded="true" height="68" name="Generate Data by User Specification (3)" width="90" x="45" y="289">
    <parameter key="Ingridient" value="&quot;Vitamin C&quot;"/>
    </list>
    <operator activated="true" class="append" compatibility="7.3.001" expanded="true" height="124" name="Append" width="90" x="380" y="85"/>
    <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/>
    <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/>
    <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 3"/>
    <connect from_op="Append" from_port="merged set" to_port="out 1"/>
    </process>
    <description align="center" color="transparent" colored="false" width="126">Generate Data</description>
    <operator activated="true" class="aggregate" compatibility="7.3.001" expanded="true" height="82" name="Aggregate" width="90" x="179" y="85">
    <parameter key="Ingridient" value="concatenation"/>
    </list>
    <parameter key="group_by_attributes" value="Drug Name|Drug ID"/>
    <operator activated="true" class="rename" compatibility="7.3.001" expanded="true" height="82" name="Rename" width="90" x="313" y="85">
    <parameter key="old_name" value="concat(Ingridient)"/>
    <parameter key="new_name" value="Ingridient"/>
    <list key="rename_additional_attributes"/>
    <operator activated="true" class="split" compatibility="7.3.001" expanded="true" height="82" name="Split" width="90" x="514" y="85">
    <parameter key="attribute" value="Ingridient"/>
    <parameter key="split_pattern" value="\|"/>
    <connect from_op="Subprocess" from_port="out 1" to_op="Aggregate" to_port="example set input"/>
    <connect from_op="Aggregate" from_port="example set output" to_op="Rename" to_port="example set input"/>
    <connect from_op="Rename" from_port="example set output" to_op="Split" to_port="example set input"/>
    <connect from_op="Split" from_port="example set output" to_port="result 1"/>
    </process>
    </process>
  • Thomas_Ott
    That's a tricky one. Maybe @mschmitz might know.
  • MartinLiebig
    MartinLiebig
    Answer ✓
    Hey,
    Best,
    Martin
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    </list>
    </list>
    </list>
    </process>
    </list>
    </process>
    </process>
  • arsalan_karim
    Wooh.. that was super... I did some playing around as I had 7 more attributes to handle as well.. but your tip helped me solve this...
    Thanks
    Arsalan
