hi...can you please confirm that upgrading from RM7.4 to 7.5 is just an EAR file replacement and not a complete new install? That's what the download page says but I just want to make sure.
Thanks.
Scott
indeed, 7.4 -> 7.5 is just the ear file
Anything earlier -> 7.5 requires the installer.
Marco
@sgenzer yes I can confirm it's just an ear you need as I upgraded our development one with no issues.
I'm 99% confident that it is just an EAR replacement but let me double check with Development.
awesome. Thanks all. I will also update the AWS RM Server public AMI that I am maintaining if anyone is interested.
ok first update went well...only one minor thing. I notice that in System Settings, the com.rapidanalytics.version.configured remains unchanged to 7.4.000. Should I change this manually to 7.5.000?
that is only used internally to determine if after an upgrade of RM Server there needs to be a migration of sorts to accomodate for some changes. As there were no such changes this time around, the version is not bumped.
You can safely ignore that
and to preemptively add to this: You can also upgrade to RM Server 7.5.1 with just replacing the .ear file (both from 7.4.0 directly as well as from 7.5.0)
