Hi! When I set css_location on my rapidminer service, (my css "https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap.min.css"). The generated URL is /internal/rest/resourses/https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap.min.css, how to remove "/internal/rest/resourses/" or where are this path?
I don't think you can reference exterior CSS files like from bootstrrap. You'd have to upload them to the Server.
Where i upload css file? beside, the upload file is on this path "/internal/rest/resourses/"?
Thanks
That's pretty easy. In the Browse Repository section of the Server web interface, there is an upload file option. See below
I upload css file but the path is wrong. Check this:
You have a typo in your path to the css you posted:
it is not resourses but resources
Best,
Edin
An example to make it easier to follow:
reference the css in your Web App
Hope this helps,
