Could anybody please give me a suggestion which data mining methods could be used for optimalization of production processes (line). For example I have a bicycle production line with several defined workstations. As input data I have an excel file containig numerical data, e.g. time per station, cumulative time, effectivity of workstation. Main goal is to improve time management and procution time.
Any suggestions would be appreciated.
Thanks a lot.
You should check out the webinar that RapidMiner recently published on process mining with the free RapidProM extension, available here: https://rapidminer.com/resource/process-mining/
It shows how RapidMiner can be used to do process analysis and investigation that may have applications related to your question.
