Greetings,
I have been trying to process Facebook data for analysis. Is there a way to pull (comments, likes, shares) from Facebook on Rapidminer like Twitter search operator?
Respectfully
@AleckN
The current extension pulls only pages and the posts for a search term. The next build will have operators for pulling shares, likes, and comments for a particular post. It's under development and hopefully, it will be available in 2-3 days.
Zapier? Is that on the marketplace? For some reason I do not see it, maybe just tierd.
I think the correct name for the operator is "Trigger Zapier" operator. It's located under the Data Access > Applications folder
Thomas, i use the find pages facebook operator and it brings back the page ids, but connecting it with find page content does not produce any results. Do you have a tip for me?
Thanks Klaus
hello @Klaus_FRA - welcome to the community. The Facebook Extension was just published a week or so ago. To be honest, I only started using it this morning and find it a little clunky. Here's what I built to look for "rapidminer":
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.0.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="facebook:MyOperator2" compatibility="1.0.000" expanded="true" height="68" name="Find Pages" width="90" x="179" y="34"> <parameter key="FB Connection" value="Facebook"/> <parameter key="Query" value="rapidminer"/> </operator> <operator activated="true" class="loop_examples" compatibility="8.0.000" expanded="true" height="103" name="Loop Examples" width="90" x="313" y="34"> <process expanded="true"> <operator activated="true" class="extract_macro" compatibility="8.0.000" expanded="true" height="68" name="Extract Macro" width="90" x="45" y="34"> <parameter key="macro" value="page"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="Page ID"/> <parameter key="example_index" value="%{example}"/> <list key="additional_macros"> <parameter key="name" value="Page Name"/> </list> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="8.0.000" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="246" y="34"> <list key="attribute_values"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="facebook:fb_conn" compatibility="1.0.000" expanded="true" height="68" name="Find Page Content" width="90" x="380" y="34"> <parameter key="Page ID" value="%{page}"/> <parameter key="FB Connection" value="Facebook"/> </operator> <operator activated="true" class="generate_attributes" compatibility="8.0.000" expanded="true" height="82" name="Generate Attributes" width="90" x="514" y="34"> <list key="function_descriptions"> <parameter key="Page Name" value="%{name}"/> <parameter key="Page ID" value="%{page}"/> </list> </operator> <connect from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Find Page Content" to_port="example set"/> <connect from_op="Find Page Content" from_port="example set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="output 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="8.0.000" expanded="true" height="82" name="Append" width="90" x="447" y="85"/> <operator activated="true" class="set_role" compatibility="8.0.000" expanded="true" height="82" name="Set Role" width="90" x="581" y="85"> <parameter key="attribute_name" value="Page ID"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <connect from_op="Find Pages" from_port="example set" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Scott
@sgenzer @Klaus_FRA we are working on the extension to fix the existing issue and add more features. Hopefully, a new build will be coming tomorrow.
Here is a sample process file where you can fetch all the posts with a particular term from various pages. Please create a new facebook connection before running it.
<?xml version="1.0" encoding="UTF-8"?><process version="7.6.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.6.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value="kamal.flyhigh@gmail.com"/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="facebook:FindPages" compatibility="1.0.001" expanded="true" height="68" name="Find Pages" width="90" x="112" y="136"> <parameter key="FB Connection" value="NewConnection"/> <parameter key="Query" value="salman khan"/> </operator> <operator activated="true" class="concurrency:loop_values" compatibility="7.6.001" expanded="true" height="82" name="Loop Values" width="90" x="313" y="34"> <parameter key="attribute" value="Page ID"/> <parameter key="iteration_macro" value="loop_value"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="facebook:FindPageContent" compatibility="1.0.001" expanded="true" height="68" name="Find Page Content" width="90" x="246" y="85"> <parameter key="Page ID" value="%{loop_value}"/> <parameter key="FB Connection" value="NewConnection"/> </operator> <connect from_port="input 1" to_op="Find Page Content" to_port="example set"/> <connect from_op="Find Page Content" from_port="example set" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="7.6.001" expanded="true" height="82" name="Append" width="90" x="514" y="34"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> <parameter key="merge_type" value="all"/> </operator> <connect from_op="Find Pages" from_port="example set" to_op="Loop Values" to_port="input 1"/> <connect from_op="Loop Values" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
this is GREAT. Thank you @curious95! Perhaps you can write a knowledgebase article for us so other users can find this information easily?
EDIT: just curious about the authentication. When I used this yesterday, the extension went through an OAuth process with Facebook (similar to our Twitter extension) which made sense to me. This morning when I updated to your new version, it goes instead to Aptus' Azure acct. What's the process here?
Also you may want to update the "About" section:
Again thank you for producing such a great idea.
This is good news indeed. This was a very necessary to RapidMiner. Looking forward to try the new build.
@curious95 @sgenzer thank you both for this fast and helpful answer. Now i can search facebook for a given term.
Hi
The FB Oauth seems like not working anymore. It is pointing to a non-functioning IP address. Anybody know how to fix this? This is from the URL copied from OAuth for FB
@snizam48 The oAuth credential page is under maintenance. It will be available soon.
@snizam48 @sgenzer The extension is up and running now.
Hi @curious95 . Tried the FB OAuth again today, but by copying the url and accessing it thru chrome, I still get the same result as below:
Hi RM Community,
I was trying to create a facebook connection today but it gave the following message -
I was able to fix this by changing http to https in authorization URL.
