I am new in RapidMiner and trying to run training model traing for historical volatility. I really don't know how to improve the accuracy rate because the highest I can get are only 60.6%. But after adding index series, all of sudden improved to 83.7%. I believe there must be something wrong. Can any expert tell me where I did something wrong because I am trying playing around to improve the accuracy rate for options volatility.
<?xml version="1.0" encoding="UTF-8"?><process version="7.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="7.4.000" expanded="true" height="68" name="Retrieve Sugar3Yrs_5153050" width="90" x="45" y="85">
<parameter key="repository_entry" value="../data/Sugar3Yrs_5153050"/>
<operator activated="true" class="set_role" compatibility="7.4.000" expanded="true" height="82" name="Set Role" width="90" x="179" y="85">
<parameter key="attribute_name" value="日期"/>
<list key="set_additional_roles">
<parameter key="HV5" value="label"/>
</list>
<operator activated="true" class="series:windowing" compatibility="7.4.000" expanded="true" height="82" name="Windowing" width="90" x="313" y="85">
<parameter key="window_size" value="5"/>
<parameter key="create_label" value="true"/>
<parameter key="label_attribute" value="HV5"/>
<parameter key="stop_on_too_small_dataset" value="false"/>
<operator activated="true" class="series:index_series" compatibility="7.4.000" expanded="true" height="82" name="Index Series" width="90" x="447" y="85">
<parameter key="attribute_name" value="label"/>
<operator activated="true" class="series:sliding_window_validation" compatibility="7.4.000" expanded="true" height="124" name="Validation" width="90" x="581" y="85">
<parameter key="training_window_width" value="5"/>
<parameter key="training_window_step_size" value="1"/>
<parameter key="test_window_width" value="5"/>
<parameter key="cumulative_training" value="true"/>
<operator activated="true" class="support_vector_machine" compatibility="7.4.000" expanded="true" height="124" name="SVM" width="90" x="112" y="34">
<parameter key="convergence_epsilon" value="0.007"/>
<connect from_port="training" to_op="SVM" to_port="training set"/>
<connect from_op="SVM" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.4.000" expanded="true" height="82" name="Apply Model" width="90" x="112" y="34">
<operator activated="true" class="series:forecasting_performance" compatibility="7.4.000" expanded="true" height="82" name="Performance" width="90" x="313" y="34">
<parameter key="horizon" value="1"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_op="Retrieve Sugar3Yrs_5153050" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Windowing" to_port="example set input"/>
<connect from_op="Windowing" from_port="example set output" to_op="Index Series" to_port="example set input"/>
<connect from_op="Index Series" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="training" to_port="result 1"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 2"/>
</process>
</process>
