Altair RISE
Nominate Yourself Now!
Set role operator not picking up attributes
User: "aidanclifford"
New Altair Community Member
Updated by Jocelyn
Hi
ive been following https://www.youtube.com/watch?v=kFGronMuchU&t=165s this tutorial
Unfortunately when i get to set role operator after the process document from data operator the set role op does has no attribute names in the dropdown. Ive followed everything in the tutorial.
Ive tried read from csv and excel op's. Im using the same dataset the guy uses in the tutorial, and on import delcare the tweet attribute as text / regualr and the  sentiment as text / label. Anyreaosn why the attribute names are not going through the process documents from data operator?
thanks
1 - 1 of 11
    User: "eldenoso"
    This apparently is because of the missing metadata. A workaround here is to type in the names manually. Alternatively you can check under Processes, whether the synchronization with the process meta data is activated.
    Philipp
