Hi Gurus,
I am new to rapidminer, I was able to implement a couple of R models(C5,rpart) in rapid miner successfully. Now I am trying to use the result of rapid miner model (Decision Tree) as input to R script , I am getting the below error :
"Incompatible data (Decision Tree) delivered at port input 1. The data delivered at the specified port was of the wrong type."
Unable to find a way to read the output of Rapidminer as input to R-script.
What I am trying to achieve:
1) I want to create a new field in the final output that explains in text how a data point was predicted as 0 or 1 (Binary -Decision Tree)
Example: if my model takes three variables a,b,c had the below conditions:
a>10
b<5 :1 {1=6,0=0}
c<5 :0 {1=0,0=3}
So in my final dataset it should have created a column for all 1's with text "a>10 & b<5" and all 0 as "C<5"
My Execute R script will have 2 inputs
1)Model (which has the conditions)
2)Test dataset+predictions (on which the text variable has to be created)
My final output should look like below
a b c Text (New column created after R script)
19 3 7 "a>10 & b<5"
5 8 3 "c<5"
Any help/tips would be greatly appreciated.
