Hi My dear
It was already mentioned when using 2D Mesh for sheet metal's , we have to use the Midsurface in making the mesh.
so If I'm going to creat 2D mesh for two sheet metal's with thickness of one and two millimeters , the real distance between two midsurf should be ' 1.5 mm' (In accordance with Appendix)
In the Example in the E_Book , tow Pats have thickness of one and two millimeters , While the distance of each other is about 3 mm.
Despite this, Is the analysis presented in the example correct?
bestregards
