Hi! I'm new to rapidminer and I'm trying to run classification models (kNN, Decision Tree, and Naive Naive Bayes). Since some of the values in my dataset are contiunuous I applied descritization technique. If I will run the processed data on kNN model will it work without a problem? (Since the values are already in ranges and not the actual data and kNN needs the real values to compute the distance). Thanks!
