Is it possibel to reduce the ouput of a log operator conditionally after its ouput?
With a kind of filter or so? For example if value > x.
PS: I output the log data into a database.
Thank you.
Yes
Have you tried the "log to data" operator. This makes an example set that you could then filter.
