I try to reduce the sample size (inner/outer sample) in a customized 'Th. Ott-SVM', to see what happens with the performance.
At one point I get this message:
What is the minimum sample size?
The error is saying that when the data set gets partioned into a Training and Test set, there are not enough examples to train on. You might need to pass more data rows to it.
