My Dear
After completing the crash analysis,How can the contact force between parts be measured at Hyper View?
Tank you
Did you request /ANIM/VECT/CNTF(not sure if this is the card)
If yes, there will be a Vector result in your animation files, then you can plot your force vectors over time.
/ANIM/VECT/CONT to output the contact forces vectors and post process with HyperView
REgards
