Parsing JSON with an illegal unquoted character
I'm using the JSON to Data operator to parse JSON from a web service call. Some of the data returned has single quotes in it ("We've noticed..."). This is causing the error:
de.rapidanalytics.ejb.service.ServiceDataSourceException Error executing process /myserver/surveys/retrieve_surveys for service retrieve_surveys: The input JSON document is malformed: 'Illegal unquoted character ((CTRL-CHAR, code 10)): has to be escaped using backslash to be included in string value at [Source: {"result":
I'm not able to change the data from the web service. Is there a way I can fix it after I retrieve it but before I pass it to be parsed? I'm retrieving it with an Execute Process operator with cURL and then a Read Document.
Thank you,
Rachel
What if you add a [replace token] operator in front and replace every non escaped single quote with an escaped one?
Something like this ?
<?xml version="1.0" encoding="UTF-8"?><process version="7.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.3.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:replace_tokens" compatibility="7.3.000" expanded="true" height="68" name="Replace Tokens" width="90" x="45" y="34">
<list key="replace_dictionary">
<parameter key="([^\\])'" value="$1\\'"/>
</list>
<operator activated="true" class="text:json_to_data" compatibility="7.3.000" expanded="true" height="82" name="JSON To Data" width="90" x="179" y="34"/>
<connect from_port="input 1" to_op="Replace Tokens" to_port="document"/>
<connect from_op="Replace Tokens" from_port="document" to_op="JSON To Data" to_port="documents 1"/>
</process>
</process>
This replaces "We've noticed..." with "We\'ve noticed..."
<context>
<input/>
<output/>
<macros/>
</context>
</list>
</process>
</process>
I'm fine with just removing the single quotes for now, if that makes the solution easier
