Rapid Miner Server Start Up
Hello guys,
I am trying to start RapidMiner Server but its throw the next error:
JBAS013412: Timeout after [300] seconds waiting for service container stability. Operation will roll back. Step that first updated the service container was 'add' at address '[
("core-service" => "management"),
("management-interface" => "native-interface")
After its says that server will rollback and its do not starts, Anyones have had its error in the past.
Thank in advance for your help!
Did you successfully install RapidMiner Server? What's the specs on the machine its on, with DB?
0 -
Yes I installed RapidMiner succesfully, y try to conect to SQL Server 2008 R2, but when it try to connect its connect succesfully, I Have 8GB in Ram Memory, Processotr Xeon E7 4850 AND 20GB Free in Disk. but when i try to run Standalone.bat its throw this error.
0 -
Hey,
are you sure that port 8080 is not blocked? Thats the default port for server.
~Martin
0 -
No I am Using por 8085 because the port 8080 is being using by other Service
0 -
as is custom with problems such as this, not much can be said without looking at the log.
Can you make your server.log (SERVER/standalone/log/server.log) available?
Marco
0 -
12:59:20,083 INFO [org.jboss.modules] (main) JBoss Modules version 1.3.6.Final-redhat-1
12:59:20,442 INFO [org.jboss.msc] (main) JBoss MSC version 1.1.5.Final-redhat-1
12:59:20,582 INFO [org.jboss.as] (MSC service thread 1-6) JBAS015899: JBoss EAP 6.4.0.Alpha1 (AS 7.5.0.Final-redhat-15) starting
12:59:20,598 DEBUG [org.jboss.as.config] (MSC service thread 1-6) Configured system properties:
awt.toolkit = sun.awt.windows.WToolkit
com.sun.jndi.ldap.connect.pool.timeout = 300000
file.encoding = Cp1252
file.encoding.pkg = sun.io
file.separator = \
java.awt.graphicsenv = sun.awt.Win32GraphicsEnvironment
java.awt.printerjob = sun.awt.windows.WPrinterJob
java.class.path = C:\RapidMinerServer\jboss-modules.jar
java.class.version = 52.0
java.endorsed.dirs = C:\Program Files\Java\jdk1.8.0_121\jre\lib\endorsed
java.ext.dirs = C:\Program Files\Java\jdk1.8.0_121\jre\lib\ext;C:\Windows\Sun\Java\lib\ext
java.home = C:\Program Files\Java\jdk1.8.0_121\jre
java.io.tmpdir = C:\Users\rg414970\AppData\Local\Temp\3\
java.library.path = C:\Program Files\Java\jdk1.8.0_121\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Program Files\HP\NCU;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\IBM\Client Access\Emulator;C:\Program Files (x86)\IBM\Client Access\Shared;C:\Program Files (x86)\IBM\Client Access\;C:\Program Files\Java\jdk1.8.0_121\bin;.
java.net.preferIPv4Stack = true
java.runtime.name = Java(TM) SE Runtime Environment
java.runtime.version = 1.8.0_121-b13
java.specification.name = Java Platform API Specification
java.specification.vendor = Oracle Corporation
java.specification.version = 1.8
java.util.logging.manager = org.jboss.logmanager.LogManager
java.vendor = Oracle Corporation
java.vendor.url = http://java.oracle.com/
java.vendor.url.bug = http://bugreport.sun.com/bugreport/
java.version = 1.8.0_121
java.vm.info = mixed mode
java.vm.name = Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name = Java Virtual Machine Specification
java.vm.specification.vendor = Oracle Corporation
java.vm.specification.version = 1.8
java.vm.vendor = Oracle Corporation
java.vm.version = 25.121-b13
javax.management.builder.initial = org.jboss.as.jmx.PluggableMBeanServerBuilder
javax.xml.datatype.DatatypeFactory = __redirected.__DatatypeFactory
javax.xml.parsers.DocumentBuilderFactory = __redirected.__DocumentBuilderFactory
javax.xml.parsers.SAXParserFactory = __redirected.__SAXParserFactory
javax.xml.stream.XMLEventFactory = __redirected.__XMLEventFactory
javax.xml.stream.XMLInputFactory = __redirected.__XMLInputFactory
javax.xml.stream.XMLOutputFactory = __redirected.__XMLOutputFactory
javax.xml.transform.TransformerFactory = __redirected.__TransformerFactory
javax.xml.validation.SchemaFactory:http://www.w3.org/2001/XMLSchema = __redirected.__SchemaFactory
javax.xml.xpath.XPathFactory:http://java.sun.com/jaxp/xpath/dom = __redirected.__XPathFactory
jboss.home.dir = C:\RapidMinerServer
jboss.host.name = sersendev02
jboss.modules.dir = C:\RapidMinerServer\modules
jboss.modules.policy-permissions = true
jboss.modules.system.pkgs = org.jboss.byteman
jboss.node.name = sersendev02
jboss.qualified.host.name = sersendev02
jboss.server.base.dir = C:\RapidMinerServer\standalone
jboss.server.config.dir = C:\RapidMinerServer\standalone\configuration
jboss.server.data.dir = C:\RapidMinerServer\standalone\data
jboss.server.deploy.dir = C:\RapidMinerServer\standalone\data\content
jboss.server.log.dir = C:\RapidMinerServer\standalone\log
jboss.server.name = sersendev02
jboss.server.persist.config = true
jboss.server.temp.dir = C:\RapidMinerServer\standalone\tmp
line.separator =logging.configuration = file:C:\RapidMinerServer\standalone\configuration/logging.properties
module.path = C:\RapidMinerServer\modules
org.jboss.boot.log.file = C:\RapidMinerServer\standalone\log\server.log
org.jboss.resolver.warning = true
org.xml.sax.driver = __redirected.__XMLReaderFactory
os.arch = amd64
os.name = Windows Server 2008 R2
os.version = 6.1
path.separator = ;
program.name = standalone.bat
sun.arch.data.model = 64
sun.boot.class.path = C:\Program Files\Java\jdk1.8.0_121\jre\lib\resources.jar;C:\Program Files\Java\jdk1.8.0_121\jre\lib\rt.jar;C:\Program Files\Java\jdk1.8.0_121\jre\lib\sunrsasign.jar;C:\Program Files\Java\jdk1.8.0_121\jre\lib\jsse.jar;C:\Program Files\Java\jdk1.8.0_121\jre\lib\jce.jar;C:\Program Files\Java\jdk1.8.0_121\jre\lib\charsets.jar;C:\Program Files\Java\jdk1.8.0_121\jre\lib\jfr.jar;C:\Program Files\Java\jdk1.8.0_121\jre\classes;C:\RapidMinerServer\jboss-modules.jar
sun.boot.library.path = C:\Program Files\Java\jdk1.8.0_121\jre\bin
sun.cpu.endian = little
sun.cpu.isalist = amd64
sun.desktop = windows
sun.io.unicode.encoding = UnicodeLittle
sun.java.command = C:\RapidMinerServer\jboss-modules.jar -mp C:\RapidMinerServer\modules -jaxpmodule javax.xml.jaxp-provider org.jboss.as.standalone -Djboss.home.dir=C:\RapidMinerServer
sun.java.launcher = SUN_STANDARD
sun.jnu.encoding = Cp1252
sun.management.compiler = HotSpot 64-Bit Tiered Compilers
sun.os.patch.level = Service Pack 1
sun.stderr.encoding = cp437
sun.stdout.encoding = cp437
user.country = US
user.dir = C:\RapidMinerServer\bin
user.home = C:\Users\rg414970
user.language = en
user.name = rg414970
user.script =
user.timezone = America/La_Paz
user.variant =
12:59:20,598 DEBUG [org.jboss.as.config] (MSC service thread 1-6) VM Arguments: -Xloggc:C:\RapidMinerServer\standalone\log\gc.log -verbose:gc -XX:+PrintGCDetails -XX:+PrintGCDateStamps -XX:+UseGCLogFileRotation -XX:NumberOfGCLogFiles=5 -XX:GCLogFileSize=3M -XX:-TraceClassUnloading -XX:+UseCompressedOops -Dprogram.name=standalone.bat -Xms1303M -Xmx2048M -XX:MaxPermSize=256M -XX:+UseG1GC -XX:MaxGCPauseMillis=50 -Djava.net.preferIPv4Stack=true -Dcom.sun.jndi.ldap.connect.pool.timeout=300000 -Djboss.modules.policy-permissions=true -Djboss.modules.system.pkgs=org.jboss.byteman -Duser.country=US -Duser.language=en -Dorg.jboss.boot.log.file=C:\RapidMinerServer\standalone\log\server.log -Dlogging.configuration=file:C:\RapidMinerServer\standalone\configuration/logging.properties -Xbootclasspath/a:C:\RapidMinerServer\jboss-modules.jar
13:00:54,509 INFO [org.xnio] (MSC service thread 1-3) XNIO Version 3.0.12.GA-redhat-1
13:00:54,524 INFO [org.jboss.as.server] (Controller Boot Thread) JBAS015888: Creating http management service using socket-binding (management-http)
13:00:54,540 INFO [org.xnio.nio] (MSC service thread 1-3) XNIO NIO Implementation Version 3.0.12.GA-redhat-1
13:00:54,836 INFO [org.jboss.remoting] (MSC service thread 1-3) JBoss Remoting version 3.3.4.Final-redhat-1
13:00:54,977 INFO [org.jboss.as.naming] (ServerService Thread Pool -- 58) JBAS011800: Activating Naming Subsystem
13:00:55,024 INFO [org.jboss.as.security] (ServerService Thread Pool -- 63) JBAS013371: Activating Security Subsystem
13:00:55,070 INFO [org.jboss.as.webservices] (ServerService Thread Pool -- 67) JBAS015537: Activating WebServices Extension
13:00:55,117 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 50) JBAS010280: Activating Infinispan subsystem.
13:00:55,039 WARN [org.jboss.as.txn] (ServerService Thread Pool -- 65) JBAS010153: Node identifier property is set to the default value. Please make sure it is unique.
13:00:55,164 INFO [org.jboss.as.jsf] (ServerService Thread Pool -- 56) JBAS012615: Activated the following JSF Implementations: [main, 1.2]
13:00:55,180 INFO [org.jboss.as.naming] (MSC service thread 1-7) JBAS011802: Starting Naming Service
13:00:55,258 INFO [org.jboss.as.mail.extension] (MSC service thread 1-6) JBAS015400: Bound mail session [java:/Mail]
13:00:55,289 INFO [org.jboss.as.security] (MSC service thread 1-7) JBAS013370: Current PicketBox version=4.1.0.Final-redhat-1
13:00:55,460 INFO [org.jboss.as.connector.logging] (MSC service thread 1-2) JBAS010408: Starting JCA Subsystem (IronJacamar 1.0.30.Final-redhat-1)
13:00:56,240 INFO [org.jboss.as.connector.subsystems.datasources] (ServerService Thread Pool -- 46) JBAS010403: Deploying JDBC-compliant driver class com.microsoft.sqlserver.jdbc.SQLServerDriver (version 4.0)
13:00:56,350 INFO [org.apache.coyote.http11.Http11Protocol] (MSC service thread 1-1) JBWEB003001: Coyote HTTP/1.1 initializing on : http-SERSENDEV02/172.17.103.141:9085
13:00:56,381 INFO [org.apache.coyote.http11.Http11Protocol] (MSC service thread 1-1) JBWEB003000: Coyote HTTP/1.1 starting on: http-SERSENDEV02/172.17.103.141:9085
13:00:56,474 INFO [org.jboss.as.server.deployment.scanner] (MSC service thread 1-3) JBAS015012: Started FileSystemDeploymentService for directory C:\RapidMinerServer\standalone\deployments
13:00:56,490 INFO [org.jboss.as.server.deployment] (MSC service thread 1-4) JBAS015876: Starting deployment of "rapidminer-server-7.4.0.ear" (runtime-name: "rapidminer-server-7.4.0.ear")
13:00:56,521 INFO [org.jboss.as.remoting] (MSC service thread 1-2) JBAS017100: Listening on 172.17.103.141:4447
13:00:56,521 INFO [org.jboss.as.remoting] (MSC service thread 1-5) JBAS017100: Listening on 172.17.103.141:9999
13:00:56,958 INFO [org.jboss.ws.common.management] (MSC service thread 1-7) JBWS022052: Starting JBoss Web Services - Stack CXF Server 4.3.2.Final-redhat-1
13:00:56,958 INFO [org.jboss.as.connector.subsystems.datasources] (MSC service thread 1-1) JBAS010400: Bound data source [java:/jdbc/RapidAnalyticsDS]
13:05:56,450 ERROR [org.jboss.as.controller.management-operation] (Controller Boot Thread) JBAS013412: Timeout after [300] seconds waiting for service container stability. Operation will roll back. Step that first updated the service container was 'add' at address '[
13:06:01,457 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.server.DeployerChainAddHandler$FinalRuntimeStepHandler@1ddad588 for operation {"operation" => "add-deployer-chains","address" => []} at address [] failed handling operation rollback -- java.util.concurrent.TimeoutException
13:06:06,465 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.domain.management.security.SecurityRealmAddHandler$ServiceInstallStepHandler@6656c265 for operation {"address" => [("core-service" => "management"),("security-realm" => "ApplicationRealm")],"operation" => "add","map-groups-to-roles" => undefined} at address [
13:06:11,472 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.domain.management.security.SecurityRealmAddHandler$ServiceInstallStepHandler@6656c265 for operation {"address" => [("core-service" => "management"),("security-realm" => "ManagementRealm")],"operation" => "add","map-groups-to-roles" => false} at address [
13:06:11,472 ERROR [org.jboss.as.server] (ServerService Thread Pool -- 47) JBAS015871: Deploy of deployment "rapidminer-server-7.4.0.ear" was rolled back with no failure message
13:06:11,487 INFO [org.jboss.as.connector.subsystems.datasources] (MSC service thread 1-8) JBAS010409: Unbound data source [java:/jdbc/RapidAnalyticsDS]
13:06:11,503 INFO [org.apache.coyote.http11.Http11Protocol] (MSC service thread 1-7) JBWEB003075: Coyote HTTP/1.1 pausing on: http-SERSENDEV02/172.17.103.141:9085
13:06:11,503 INFO [org.apache.coyote.http11.Http11Protocol] (MSC service thread 1-7) JBWEB003077: Coyote HTTP/1.1 stopping on : http-SERSENDEV02/172.17.103.141:9085
13:06:16,510 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.ParallelBootOperationStepHandler$2@78b08593 for operation {"operation" => "parallel-subsystem-boot","address" => []} at address [] failed handling operation rollback -- java.util.concurrent.TimeoutException
13:06:21,518 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@1b9e99bf for operation {"operation" => "add","host" => "localhost","port" => 25,"address" => [("socket-binding-group" => "standard-sockets"),("remote-destination-outbound-socket-binding" => "mail-smtp")],"source-interface" => undefined,"source-port" => undefined,"fixed-source-port" => undefined} at address [
13:06:26,525 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@1090699c for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "txn-status-manager")],"operation" => "add","port" => 4713,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
13:06:31,532 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@66ec3ad5 for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "txn-recovery-environment")],"operation" => "add","port" => 4712,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
13:06:36,540 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@1e94abbf for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "remoting")],"operation" => "add","port" => 4447,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
13:06:41,547 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@10398a7a for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "https")],"operation" => "add","port" => 8443,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
13:06:46,554 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@79badebe for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "http")],"operation" => "add","port" => 9085,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
13:06:51,562 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@133822cd for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "ajp")],"operation" => "add","port" => 8009,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
13:06:56,569 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@3c707f47 for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "management-https")],"operation" => "add","interface" => "management","port" => expression "${jboss.management.https.port:9443}","fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
13:07:01,577 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@5165b14a for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "management-http")],"operation" => "add","interface" => "management","port" => expression "${jboss.management.http.port:9990}","fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
13:07:06,584 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@7db6afb7 for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "management-native")],"operation" => "add","interface" => "management","port" => expression "${jboss.management.native.port:9999}","fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
13:07:11,592 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@4c5ca938 for operation {"operation" => "add","address" => [("socket-binding-group" => "standard-sockets")],"default-interface" => "public","port-offset" => expression "${jboss.socket.binding.port-offset:0}"} at address [("socket-binding-group" => "standard-sockets")] failed handling operation rollback -- java.util.concurrent.TimeoutException
13:07:16,599 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@5dd2780c for operation {"address" => [("interface" => "any")],"operation" => "add","any-ipv4-address" => true} at address [("interface" => "any")] failed handling operation rollback -- java.util.concurrent.TimeoutException
13:07:21,607 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@3960bf07 for operation {"address" => [("interface" => "unsecure")],"operation" => "add","inet-address" => expression "${jboss.bind.address.unsecure:SERSENDEV02}"} at address [("interface" => "unsecure")] failed handling operation rollback -- java.util.concurrent.TimeoutException
13:07:26,614 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@6fc5d10c for operation {"address" => [("interface" => "public")],"operation" => "add","inet-address" => expression "${jboss.bind.address:SERSENDEV02}"} at address [("interface" => "public")] failed handling operation rollback -- java.util.concurrent.TimeoutException
13:07:31,622 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@25412fbc for operation {"address" => [("interface" => "management")],"operation" => "add","inet-address" => expression "${jboss.bind.address.management:SERSENDEV02}"} at address [("interface" => "management")] failed handling operation rollback -- java.util.concurrent.TimeoutException
13:07:36,629 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@171f1285 for operation {"operation" => "add","address" => [("core-service" => "management"),("management-interface" => "http-interface")],"security-realm" => "ManagementRealm","socket-binding" => "management-http"} at address [
13:07:41,637 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@323c4380 for operation {"operation" => "add","address" => [("core-service" => "management"),("management-interface" => "native-interface")],"security-realm" => "ManagementRealm","socket-binding" => "management-native"} at address [
13:07:46,644 ERROR [org.jboss.as.controller.management-operation] (Controller Boot Thread) JBAS013413: Timeout after [5000] seconds waiting for service container stability while finalizing an operation. Process must be restarted. Step that first updated the service container was 'add' at address '[
13:07:46,644 FATAL [org.jboss.as.server] (Controller Boot Thread) JBAS015957: Server boot has failed in an unrecoverable manner; exiting. See previous messages for details.
13:11:03,543 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-4) MSC000001: Failed to start service jboss.deployment.unit."rapidminer-server-7.4.0.ear".STRUCTURE: org.jboss.msc.service.StartException in service jboss.deployment.unit."rapidminer-server-7.4.0.ear".STRUCTURE: JBAS018733: Failed to process phase STRUCTURE of deployment "rapidminer-server-7.4.0.ear"
at org.jboss.as.server.deployment.DeploymentUnitPhaseService.start(DeploymentUnitPhaseService.java:166) [jboss-as-server-7.5.0.Final-redhat-15.jar:7.5.0.Final-redhat-15]
at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1980) [jboss-msc-1.1.5.Final-redhat-1.jar:1.1.5.Final-redhat-1]
at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1913) [jboss-msc-1.1.5.Final-redhat-1.jar:1.1.5.Final-redhat-1]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [rt.jar:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [rt.jar:1.8.0_121]
at java.lang.Thread.run(Thread.java:745) [rt.jar:1.8.0_121]
Caused by: java.lang.IllegalStateException: Container is down
at org.jboss.msc.service.ServiceContainerImpl.install(ServiceContainerImpl.java:690) [jboss-msc-1.1.5.Final-redhat-1.jar:1.1.5.Final-redhat-1]
at org.jboss.msc.service.ServiceTargetImpl.install(ServiceTargetImpl.java:243) [jboss-msc-1.1.5.Final-redhat-1.jar:1.1.5.Final-redhat-1]
at org.jboss.msc.service.ServiceControllerImpl$ChildServiceTarget.install(ServiceControllerImpl.java:2433) [jboss-msc-1.1.5.Final-redhat-1.jar:1.1.5.Final-redhat-1]
at org.jboss.msc.service.ServiceBuilderImpl.install(ServiceBuilderImpl.java:345) [jboss-msc-1.1.5.Final-redhat-1.jar:1.1.5.Final-redhat-1]
at org.jboss.as.server.deployment.SubDeploymentProcessor.deploy(SubDeploymentProcessor.java:67) [jboss-as-server-7.5.0.Final-redhat-15.jar:7.5.0.Final-redhat-15]
at org.jboss.as.server.deployment.DeploymentUnitPhaseService.start(DeploymentUnitPhaseService.java:159) [jboss-as-server-7.5.0.Final-redhat-15.jar:7.5.0.Final-redhat-15]
... 5 more13:11:03,543 INFO [org.jboss.as.server.deployment] (MSC service thread 1-5) JBAS015877: Stopped deployment rapidminer-server-7.4.0.ear (runtime-name: rapidminer-server-7.4.0.ear) in 307104ms
13:11:03,559 INFO [org.jboss.as] (MSC service thread 1-8) JBAS015950: JBoss EAP 6.4.0.Alpha1 (AS 7.5.0.Final-redhat-15) stopped in 196906ms0 -
the log states that you are not using 8085 for HTTP but 9085.
13:00:56,381 INFO [org.apache.coyote.http11.Http11Protocol] (MSC service thread 1-1) JBWEB003000: Coyote HTTP/1.1 starting on: http-SERSENDEV02/172.17.103.141:9085Can you change this?
One possibility is to modify the corresponding tag
<socket-binding name="http" port="9085"/> to <socket-binding name="http" port="8085"/>
in the standalone.xml file but it might be easier to reinstall the server.
Best,
Edin
1
