no access to SQL server using proxy
User: "kayman"
New Altair Community Member
Updated by Jocelyn
I have some strange behaviour trying to access our company databases. I can access them when using direct (no proxy), but the moment I select proxy I cannot access the servers anymore (MS SQL).
This is pretty annoying as I have a process crawling websites that need the proxy to be set, and I want to load the results to our databases but that doesn't work unless I disable the proxy.
Any advice on what I need to set to also get access to my databases using proxy?
I'm using RM7.4
1 - 2 of 21
    User: "BalazsBaranyRM"
    Accepted Answer
    did you try listing the name or ip address of your database server in the "No proxy for" list? This only works if you're using the Manual Proxy setting.
    Balázs
    User: "kayman"
    OP
    Accepted Answer
    Sorry, too fast again... I can access my databases now with manual proxy but I loose access to the internet :-(
    So this is what I have :
    Using system proxy : access to the web but not to database or localhost RM server
    Using direct (no proxy) : access to database, localhost RM server but not web
    Using manual proxy and no proxy for localhost|mydb1|mydb2 : access to database, localhost RM Server but not to web anymore
    What would be the magic recepy ?
    [UPDATE] I had to remove the socks settigns, that did the trick for me.
    Now I get access to all of them using manual proxy, thanks for the support !
