Hello everybody,
The following is a simplified version of my example set:
ID Name Costs Time
1 Example1 1.40 00:30
2 Example2 1,50 01:00
How can I fill in quarterly times. In this case RM should fill in the Time 00:00, 00:15 and replace the missing values (that obviously Missing value operator) with the previous values. And he should fill in the times 01:15, 01:30, 01:45,...,23:45. How can I achieve this? My solution was not as elegant as I just put the values into an excel sheet and joined it with the example set (righter join), so that all examples of the continous times are taken and joined with the table above. BUT if the example set contains more than 1Mio examples this method doesn't work (due to excel limitations). Is there a way to do this just with rapidminer?
Best regards
*Sorry for any mistakes, I am not a native speaker :-)*
