In my process I first transformed a time into numerics (minutes relative to day). I can't find an operator that withdraws that?Thank you
there is no way to reverse this. This transformation is removing information. You might want to join the original data though.
~Martin
Martin is correct, you'd have to use a Multiply Data operator before the transformation and maybe a Generate ID operator so you can join the original and transformed data set back together via Join operator.
