If you're using Aylien or Rosette they have an API limit for free. Maybe you exceeded it.
Please post either your process or a screenshot of what goes wrong.
I'm also having this issue. In my attempts to use AYLIEN's sentiment analysis everytime I attempt to run the process it states I need to provide a value for input attribute. It doesn't automatically link the attribute (I believe to be my Create Document operator) -- if I drag the text file directly into the processing space as its own db it seems to work. Not sure if it requires some kind of preprocessing to acquire or satisfy the input attribute requirement or what.
