11:59:37,486 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-1) MSC000001: Failed to start service jboss.remoting.server.remoting-connector: org.jboss.msc.service.StartException in service jboss.remoting.server.remoting-connector: JBAS017112: Address already in use: bind 0.0.0.0:4447
at org.jboss.as.remoting.AbstractStreamServerService.start(AbstractStreamServerService.java:110)
at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1980) [jboss-msc-1.1.5.Final-redhat-1.jar:1.1.5.Final-redhat-1]
at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1913) [jboss-msc-1.1.5.Final-redhat-1.jar:1.1.5.Final-redhat-1]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [rt.jar:1.8.0_112]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [rt.jar:1.8.0_112]
at java.lang.Thread.run(Unknown Source) [rt.jar:1.8.0_112]
Caused by: java.net.BindException: Address already in use: bind
at sun.nio.ch.Net.bind0(Native Method) [rt.jar:1.8.0_112]
at sun.nio.ch.Net.bind(Unknown Source) [rt.jar:1.8.0_112]
at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source) [rt.jar:1.8.0_112]
at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source) [rt.jar:1.8.0_112]
at org.xnio.nio.NioXnioWorker.createTcpServer(NioXnioWorker.java:289)
at org.xnio.XnioWorker.createStreamServer(XnioWorker.java:130)
at org.jboss.remoting3.remote.RemoteConnectionProvider$ProviderInterface.createServer(RemoteConnectionProvider.java:301)
at org.jboss.as.remoting.AbstractStreamServerService.start(AbstractStreamServerService.java:102)
... 5 more
11:59:43,213 INFO [org.jboss.as.jpa] (ServerService Thread Pool -- 162) JBAS011403: Stopping Persistence Unit Service 'rapidminer-server-7.3.1.ear/rapidminer-server-ejb.jar#RapidRepositoryEntity'
11:59:44,820 INFO [org.jboss.ws.common.management] (MSC service thread 1-3) JBWS022052: Starting JBoss Web Services - Stack CXF Server 4.3.2.Final-redhat-1
11:59:46,452 INFO [org.jboss.as.server.deployment] (MSC service thread 1-8) JBAS015974: Stopped subdeployment (runtime-name: rapidminer-server-ejb.jar) in 21570ms
12:00:02,429 INFO [org.jboss.as.server.deployment] (MSC service thread 1-5) JBAS015974: Stopped subdeployment (runtime-name: rapidminer-server-war.war) in 37547ms
12:00:07,183 INFO [org.jboss.vfs] (MSC service thread 1-6) VFS000002: Failed to clean existing content for temp file provider of type deployment. Enable DEBUG level log to find what caused this
12:00:45,450 INFO [org.jboss.as.server.deployment] (MSC service thread 1-4) JBAS015877: Stopped deployment rapidminer-server-7.3.1.ear (runtime-name: rapidminer-server-7.3.1.ear) in 80569ms
12:00:45,584 INFO [org.jboss.as.server.deployment] (MSC service thread 1-8) JBAS015876: Starting deployment of "rapidminer-server-7.3.1.ear" (runtime-name: "rapidminer-server-7.3.1.ear")
12:04:27,021 ERROR [org.jboss.as.controller.management-operation] (Controller Boot Thread) JBAS013412: Timeout after [300] seconds waiting for service container stability. Operation will roll back. Step that first updated the service container was 'add' at address '[
("core-service" => "management"),
("management-interface" => "native-interface")
12:04:32,174 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.server.DeployerChainAddHandler$FinalRuntimeStepHandler@3de7de71 for operation {"operation" => "add-deployer-chains","address" => []} at address [] failed handling operation rollback -- java.util.concurrent.TimeoutException
12:04:37,175 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.domain.management.security.SecurityRealmAddHandler$ServiceInstallStepHandler@45d4f023 for operation {"address" => [("core-service" => "management"),("security-realm" => "ApplicationRealm")],"operation" => "add","map-groups-to-roles" => undefined} at address [
12:04:42,177 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.domain.management.security.SecurityRealmAddHandler$ServiceInstallStepHandler@45d4f023 for operation {"address" => [("core-service" => "management"),("security-realm" => "ManagementRealm")],"operation" => "add","map-groups-to-roles" => false} at address [
12:04:42,525 ERROR [org.jboss.as.server] (ServerService Thread Pool -- 28) JBAS015871: Deploy of deployment "rapidminer-server-7.3.1.ear" was rolled back with no failure message
12:04:44,066 INFO [org.jboss.as.connector.subsystems.datasources] (MSC service thread 1-7) JBAS010409: Unbound data source [java:/jdbc/RapidAnalyticsDS]
12:04:47,636 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.ParallelBootOperationStepHandler$2@4a4042ae for operation {"operation" => "parallel-subsystem-boot","address" => []} at address [] failed handling operation rollback -- java.util.concurrent.TimeoutException
12:04:48,823 INFO [org.apache.coyote.http11.Http11Protocol] (MSC service thread 1-8) JBWEB003075: Coyote HTTP/1.1 pausing on: http-/0.0.0.0:8080
12:04:48,956 INFO [org.apache.coyote.http11.Http11Protocol] (MSC service thread 1-8) JBWEB003077: Coyote HTTP/1.1 stopping on : http-/0.0.0.0:8080
12:04:52,636 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@3bba3983 for operation {"operation" => "add","host" => "localhost","port" => 25,"address" => [("socket-binding-group" => "standard-sockets"),("remote-destination-outbound-socket-binding" => "mail-smtp")],"source-interface" => undefined,"source-port" => undefined,"fixed-source-port" => undefined} at address [
12:04:57,656 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@391dd6f3 for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "txn-status-manager")],"operation" => "add","port" => 4713,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
12:05:02,658 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@151aa8f for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "txn-recovery-environment")],"operation" => "add","port" => 4712,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
12:05:07,658 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@22a27dab for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "remoting")],"operation" => "add","port" => 4447,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
12:05:12,682 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@2a6035eb for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "https")],"operation" => "add","port" => 8443,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
12:05:17,682 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@12f5539a for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "http")],"operation" => "add","port" => 8080,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
12:05:22,690 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@5022987f for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "ajp")],"operation" => "add","port" => 8009,"interface" => undefined,"fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
12:05:27,735 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@12e908d5 for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "management-https")],"operation" => "add","interface" => "management","port" => expression "${jboss.management.https.port:9443}","fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
12:05:32,737 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@1cec5722 for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "management-http")],"operation" => "add","interface" => "management","port" => expression "${jboss.management.http.port:9990}","fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
12:05:37,815 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@2bf07e4e for operation {"address" => [("socket-binding-group" => "standard-sockets"),("socket-binding" => "management-native")],"operation" => "add","interface" => "management","port" => expression "${jboss.management.native.port:9999}","fixed-port" => undefined,"multicast-address" => undefined,"multicast-port" => undefined,"client-mappings" => undefined} at address [
12:05:43,060 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@436db334 for operation {"operation" => "add","address" => [("socket-binding-group" => "standard-sockets")],"default-interface" => "any","port-offset" => expression "${jboss.socket.binding.port-offset:0}"} at address [("socket-binding-group" => "standard-sockets")] failed handling operation rollback -- java.util.concurrent.TimeoutException
12:05:48,149 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@31e06e0c for operation {"address" => [("interface" => "any")],"operation" => "add","any-ipv4-address" => true} at address [("interface" => "any")] failed handling operation rollback -- java.util.concurrent.TimeoutException
12:05:46,771 ERROR [org.jboss.as.controller.management-operation] (DeploymentScanner-threads - 2) JBAS013412: Timeout after [300] seconds waiting for service container stability. Operation will roll back. Step that first updated the service container was 'full-replace-deployment' at address '[]'
12:05:53,149 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@17439733 for operation {"address" => [("interface" => "unsecure")],"operation" => "add","inet-address" => expression "${jboss.bind.address.unsecure:DELL}"} at address [("interface" => "unsecure")] failed handling operation rollback -- java.util.concurrent.TimeoutException
12:05:58,151 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@6f6a085c for operation {"address" => [("interface" => "public")],"operation" => "add","inet-address" => expression "${jboss.bind.address:DELL}"} at address [("interface" => "public")] failed handling operation rollback -- java.util.concurrent.TimeoutException
12:06:03,151 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@16c90cc2 for operation {"address" => [("interface" => "management")],"operation" => "add","inet-address" => expression "${jboss.bind.address.management:DELL}"} at address [("interface" => "management")] failed handling operation rollback -- java.util.concurrent.TimeoutException
12:06:04,885 ERROR [org.jboss.as.controller.management-operation] (DeploymentScanner-threads - 2) JBAS013413: Timeout after [5000] seconds waiting for service container stability while finalizing an operation. Process must be restarted. Step that first updated the service container was 'full-replace-deployment' at address '[]'
12:06:05,584 INFO [org.jboss.as.controller] (DeploymentScanner-threads - 2) JBAS014774: Service status report
JBAS014777: Services which failed to start: service jboss.web.connector.http: org.jboss.msc.service.StartException in service jboss.web.connector.http: JBAS018007: Error starting web connector
12:06:10,571 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@34a1bd70 for operation {"operation" => "add","address" => [("core-service" => "management"),("management-interface" => "http-interface")],"security-realm" => "ManagementRealm","socket-binding" => "management-http"} at address [
12:06:15,640 ERROR [org.jboss.as.controller.client] (Controller Boot Thread) JBAS014781: Step handler org.jboss.as.controller.AbstractAddStepHandler$1@265838c3 for operation {"operation" => "add","address" => [("core-service" => "management"),("management-interface" => "native-interface")],"security-realm" => "ManagementRealm","socket-binding" => "management-native"} at address [
12:06:20,778 ERROR [org.jboss.as.controller.management-operation] (Controller Boot Thread) JBAS013413: Timeout after [5000] seconds waiting for service container stability while finalizing an operation. Process must be restarted. Step that first updated the service container was 'add' at address '[
12:06:26,331 FATAL [org.jboss.as.server] (Controller Boot Thread) JBAS015957: Server boot has failed in an unrecoverable manner; exiting. See previous messages for details.
12:06:52,238 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-6) MSC000001: Failed to start service jboss.deployment.unit."rapidminer-server-7.3.1.ear".STRUCTURE: org.jboss.msc.service.StartException in service jboss.deployment.unit."rapidminer-server-7.3.1.ear".STRUCTURE: JBAS018733: Failed to process phase STRUCTURE of deployment "rapidminer-server-7.3.1.ear"
at org.jboss.as.server.deployment.DeploymentUnitPhaseService.start(DeploymentUnitPhaseService.java:166) [jboss-as-server-7.5.0.Final-redhat-15.jar:7.5.0.Final-redhat-15]
Caused by: java.lang.IllegalStateException: Container is down
at org.jboss.msc.service.ServiceContainerImpl.install(ServiceContainerImpl.java:690) [jboss-msc-1.1.5.Final-redhat-1.jar:1.1.5.Final-redhat-1]
at org.jboss.msc.service.ServiceTargetImpl.install(ServiceTargetImpl.java:243) [jboss-msc-1.1.5.Final-redhat-1.jar:1.1.5.Final-redhat-1]
at org.jboss.msc.service.ServiceControllerImpl$ChildServiceTarget.install(ServiceControllerImpl.java:2433) [jboss-msc-1.1.5.Final-redhat-1.jar:1.1.5.Final-redhat-1]
at org.jboss.msc.service.ServiceBuilderImpl.install(ServiceBuilderImpl.java:345) [jboss-msc-1.1.5.Final-redhat-1.jar:1.1.5.Final-redhat-1]
at org.jboss.as.server.deployment.SubDeploymentProcessor.deploy(SubDeploymentProcessor.java:67) [jboss-as-server-7.5.0.Final-redhat-15.jar:7.5.0.Final-redhat-15]
at org.jboss.as.server.deployment.DeploymentUnitPhaseService.start(DeploymentUnitPhaseService.java:159) [jboss-as-server-7.5.0.Final-redhat-15.jar:7.5.0.Final-redhat-15]
... 5 more
