I have created a few macro as below:
- c_senior (value: 220)
- c_assistant (value: 150)
May someone kindly advise how can I replace the value in a column (eg. Rate) based on the condition from other columns?
Example: I would need to change the Rate column value from 200 to 220 if
- Column "badge_id" start with "E" and
- Column "rank" is "senior"
