Send Mail with Data
User: "basis"
New Altair Community Member
Updated by Jocelyn
Hello All,
There is a couple of similar posts but no proper answer given so I wanted to take my chance.
I am trying to use Send Mail operator with macro.
Form what I get is you are able to send data value if you specify attribute and index. So if one has 1 value to send, things are easy.
However I have a process that outputs 2 rows of data table and I would like to send the both values in the same email.
To be more specific my data is like:
machine_ID
M_0212
M_0221
and I am trying to send an email like:
Dear receiver,
Problematic machines are:
M_0212
M_0221
The thing is this needs to be generic, I might not always have 2 values so hardcoding 2 is not an option. I feel like I need the loop operator and it will count total number of rows and create an array of values in the form of a macro.
But I couldn't figure out how to do that (if possible).
Any help is highly appreciated.
Best
G
1 - 2 of 21
    Hey,
    give us a week or two. If this is not an option, write me a PM and i can give you a two operator solution.
    ~Martin
    User: "JEdward"
    Here's a lazy solution.
    <?xml version="1.0" encoding="UTF-8"?><process version="7.3.000">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.3.000" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="generate_data_user_specification" compatibility="7.3.000" expanded="true" height="68" name="Generate Data by User Specification" width="90" x="112" y="85">
    <list key="attribute_values">
    <parameter key="M_0212" value="&quot;Very Broken&quot;"/>
    <parameter key="M_0221" value="&quot;Super Faulty&quot;"/>
    </list>
    <operator activated="true" class="transpose" compatibility="7.3.000" expanded="true" height="82" name="Transpose" width="90" x="112" y="187"/>
    <operator activated="true" class="write_csv" compatibility="7.3.000" expanded="true" height="82" name="Write CSV" width="90" x="246" y="187">
    <parameter key="column_separator" value="|"/>
    <parameter key="quote_nominal_values" value="false"/>
    <operator activated="true" class="text:read_document" compatibility="7.3.000" expanded="true" height="68" name="Read Document" width="90" x="179" y="340"/>
    <operator activated="true" class="text:documents_to_data" compatibility="7.3.000" expanded="true" height="82" name="Documents to Data" width="90" x="179" y="442">
    <parameter key="text_attribute" value="fault"/>
    <operator activated="true" class="extract_macro" compatibility="7.3.000" expanded="true" height="68" name="Extract Macro" width="90" x="380" y="493">
    <parameter key="macro" value="thisFaultBad"/>
    <parameter key="macro_type" value="data_value"/>
    <parameter key="attribute_name" value="fault"/>
    <parameter key="example_index" value="1"/>
    <list key="additional_macros"/>
    <operator activated="true" class="text:create_document" compatibility="7.3.000" expanded="true" height="68" name="Create Document" width="90" x="447" y="340">
    <parameter key="text" value="Hey there,&#10;&#10;You know you have a problem with your machine. &#10;&#10;%{thisFaultBad}&#10;&#10;Totes wanted to let you know. &#10;&#10;See ya!"/>
    <connect from_op="Generate Data by User Specification" from_port="output" to_op="Transpose" to_port="example set input"/>
    <connect from_op="Transpose" from_port="example set output" to_op="Write CSV" to_port="input"/>
    <connect from_op="Write CSV" from_port="file" to_op="Read Document" to_port="file"/>
    <connect from_op="Read Document" from_port="output" to_op="Documents to Data" to_port="documents 1"/>
    <connect from_op="Documents to Data" from_port="example set" to_op="Extract Macro" to_port="example set"/>
    <connect from_op="Create Document" from_port="output" to_port="result 1"/>
    </process>
    </process>
