Twitter Sentiment Analysis- results bias positive/negative
mbinsaip
mbinsaip New Altair Community Member
I am new user of RapidMiner. I am following some tutorial from rapidminer users in youtube to build a twitter sentiment analysis process. It was run well but the result was not really good. For example, when I used decision tree, it will give all positive sentiment (no negative or neutral). When I used SVM, the results will all negative. My trainning data was  mixed positive and negative. Can anaybody advice. Thanks.
saip
  • Telcontar120
    Telcontar120 New Altair Community Member
    It's very difficult to say without knowing the details of the data and looking at the model output.  It is possible that your data does not contain sufficient attributes with predictive power to generate a differentiated model.  So, for example, your decision tree may not have any splits at all and just contains the root class, which simply predicts the majority class.
  • Thomas_Ott
    So this highlights the issue that some algorithms are better than others for a particular task.  If this is a standard binonmal (2 labels) classification task, you could try using the ROC operator and embed different algorithms in to do a "model bakeoff" and see which one gives you the best general AUC.
