SIMSOLID 2023.1 CRASHING
Dear Support Team,
I am currently using SIMSOLID Software version 2023.1 and have encountered an issue where the software crashes while importing certain model files.
Although SIMSOLID Software is designed to handle large assemblies, it sometimes crashes when importing larger model files. This issue does not occur with all model files, but only with specific ones.
I have tested this on both Windows 10 Pro and Windows 11 Pro, and the issue persists across both operating systems.
Could you please assist me in resolving this issue?
Thank you for your support.
GSVP
I also face similar issue. Just wondering if the user needs to maintain required space in the Local drive to run the solution.
And also Noticed it takes more RAM and memory for large models during solving
AAnalyzing the Connections
Solving the Equation system at pass 4
Processing Part Physics
Please suggest if required scratch needs to be maintained ?
