I hope that someone can help me by my problem.
My task is to make a sales forecast for different products by means of time series analysis. For this I use the process inspired by Thomas Ott:
process
So I have a question:
By the "Windowing" operator is it possible to chose the horizon with 0 and with this setting I get an accuracy from 0.935 and a meaningful graph.
Can I do that? All the examples I had found used the horizon=1. But when I change to 1 the results are worse and the lines in the graph can not match, because with horizon=1 the prediction value is not in the same row how the correct value.
I hope someone can help me.
Best regards
Tina
(Sorry for my worse English)
<?xml version="1.0" encoding="UTF-8"?><process version="7.3.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.3.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="7.3.001" expanded="true" height="68" name="Read Excel" width="90" x="45" y="34">
<parameter key="excel_file" value="C:\Users\Tina Grundmann\Dropbox\3MBACS\Projekt\RapidMiner\daten\trainingsdaten.xlsx"/>
<parameter key="imported_cell_range" value="A1:F66"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="1A3=1-1 Material Verbrauch.true.integer.attribute"/>
<parameter key="1" value="1A3=1-2 Material Verbrauch.true.integer.attribute"/>
<parameter key="2" value="1A3=2-1 Material Verbrauch.true.integer.attribute"/>
<parameter key="3" value="1A3=4-2 Material Verbrauch.true.integer.attribute"/>
<parameter key="4" value="3Z8 Material Verbrauch.true.integer.attribute"/>
<parameter key="5" value="Monat\.KalJahr.true.date_time.id"/>
</list>
<operator activated="true" class="set_role" compatibility="7.3.001" expanded="true" height="82" name="Set Role" width="90" x="45" y="136">
<parameter key="attribute_name" value="Monat.KalJahr"/>
<operator activated="true" class="select_attributes" compatibility="7.3.001" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34">
<parameter key="attributes" value="1A3=1-1 Material Verbrauch|Monat.KalJahr"/>
<operator activated="true" class="series:windowing" compatibility="7.3.000" expanded="true" height="82" name="Windowing" width="90" x="313" y="34">
<parameter key="window_size" value="2"/>
<parameter key="create_label" value="true"/>
<parameter key="label_attribute" value="1A3=1-1 Material Verbrauch"/>
<parameter key="horizon" value="0"/>
<parameter key="stop_on_too_small_dataset" value="false"/>
<operator activated="true" class="series:sliding_window_validation" compatibility="7.3.000" expanded="true" height="124" name="Validation" width="90" x="447" y="34">
<parameter key="training_window_width" value="32"/>
<parameter key="training_window_step_size" value="1"/>
<parameter key="test_window_width" value="32"/>
<operator activated="true" class="neural_net" compatibility="7.3.001" expanded="true" height="82" name="Neural Net" width="90" x="112" y="34">
<list key="hidden_layers"/>
<operator activated="false" class="polynomial_regression" compatibility="7.3.001" expanded="true" height="82" name="Polynomial Regression" width="90" x="112" y="136"/>
<connect from_port="training" to_op="Neural Net" to_port="training set"/>
<connect from_op="Neural Net" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.3.001" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34">
<operator activated="true" class="series:forecasting_performance" compatibility="7.3.000" expanded="true" height="82" name="Performance" width="90" x="179" y="34">
<parameter key="horizon" value="1"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="true" class="read_excel" compatibility="7.3.001" expanded="true" height="68" name="Read Excel (2)" width="90" x="45" y="238">
<parameter key="excel_file" value="C:\Users\Tina Grundmann\Dropbox\3MBACS\Projekt\RapidMiner\daten\evaluierungsdaten.xlsx"/>
<parameter key="imported_cell_range" value="A1:F28"/>
</list>
</list>
<operator activated="true" class="set_role" compatibility="7.3.001" expanded="true" height="82" name="Set Role (2)" width="90" x="179" y="136">
<operator activated="true" class="select_attributes" compatibility="7.3.001" expanded="true" height="82" name="Select Attributes (2)" width="90" x="179" y="238">
<operator activated="true" class="series:windowing" compatibility="7.3.000" expanded="true" height="82" name="Windowing (2)" width="90" x="313" y="238">
<operator activated="true" class="apply_model" compatibility="7.3.001" expanded="true" height="82" name="Apply Model (2)" width="90" x="447" y="238">
<operator activated="true" class="select_attributes" compatibility="7.3.001" expanded="true" height="82" name="Select Attributes (3)" width="90" x="581" y="187">
<parameter key="attributes" value="Monat.KalJahr|prediction(label)|1A3=1-1 Material Verbrauch-0"/>
<connect from_op="Read Excel" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Windowing" to_port="example set input"/>
<connect from_op="Windowing" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_op="Validation" from_port="training" to_port="result 1"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 2"/>
<connect from_op="Read Excel (2)" from_port="output" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Windowing (2)" to_port="example set input"/>
<connect from_op="Windowing (2)" from_port="example set output" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Select Attributes (3)" to_port="example set input"/>
<connect from_op="Select Attributes (3)" from_port="example set output" to_port="result 3"/>
</process>
</process>
