Imputing Nulls using Grouped by values
User: "garg2409"
New Altair Community Member
Updated by Jocelyn
Hello Community,
Can we impute Null values with Grouped by some column of Non Null Values?
Eg : In titanic problem, I want to impute Age column with the mean age grouped by Sex. Now, this logic can be as complex as we want. Is there a functionality in RM to write our own rules for imputing Nulls?
P.S. I have seen the Imputing Missing Values operator. KNN may not work for all cases so we may need custom rules.
1 - 1 of 11
    User: "MartinLiebig"
    Accepted Answer
    what about loop values, filter example, replace missings? :)
     Edit: a quicker way uses Aggregate and join. An example is attached.
    ~Martin
    <?xml version="1.0" encoding="UTF-8"?><process version="7.3.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.3.001" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="retrieve" compatibility="7.3.001" expanded="true" height="68" name="Retrieve Titanic" width="90" x="112" y="136">
    <parameter key="repository_entry" value="//Samples/data/Titanic"/>
    <operator activated="true" class="multiply" compatibility="7.3.001" expanded="true" height="103" name="Multiply" width="90" x="246" y="136"/>
    <operator activated="true" class="aggregate" compatibility="7.3.001" expanded="true" height="82" name="Aggregate" width="90" x="380" y="34">
    <parameter key="Age" value="average"/>
    </list>
    <parameter key="group_by_attributes" value="Sex"/>
    <operator activated="true" class="join" compatibility="7.3.001" expanded="true" height="82" name="Join" width="90" x="581" y="136">
    <parameter key="join_type" value="right"/>
    <parameter key="use_id_attribute_as_key" value="false"/>
    <list key="key_attributes">
    <parameter key="Sex" value="Sex"/>
    </list>
    <operator activated="true" class="generate_attributes" compatibility="7.3.001" expanded="true" height="82" name="Generate Attributes" width="90" x="715" y="136">
    <parameter key="Age" value="if(missing(Age),[average(Age)],Age)"/>
    </list>
    <operator activated="true" class="select_attributes" compatibility="7.3.001" expanded="true" height="82" name="Select Attributes" width="90" x="916" y="136">
    <parameter key="attribute" value="average(Age)"/>
    <connect from_op="Retrieve Titanic" from_port="output" to_op="Multiply" to_port="input"/>
    <connect from_op="Multiply" from_port="output 1" to_op="Aggregate" to_port="example set input"/>
    <connect from_op="Multiply" from_port="output 2" to_op="Join" to_port="right"/>
    <connect from_op="Aggregate" from_port="example set output" to_op="Join" to_port="left"/>
    <connect from_op="Join" from_port="join" to_op="Generate Attributes" to_port="example set input"/>
    <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
    <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/>
    </process>
    </process>
