Hi there, I'm currently trying to extract multiple paragraphs from xhtml. I am using the "Generate Extract" operator with xPath as query for this.
The xPath query should look like:
//xhtml:p/text()
and the name space like:
http://www.w3.org/1999/xhtml
But I receive only a small fragment of the first paragraph (seem like it's only the first word until a space occurs).
Here is my process:
<?xml version="1.0" encoding="UTF-8"?><process version="7.3.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.3.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="7.3.001" expanded="true" height="68" name="Retrieve Fussball-pages_sample" width="90" x="45" y="34">
<parameter key="repository_entry" value="//Local Repository/SpiegelMining/Fussball-pages_sample"/>
<operator activated="true" class="generate_id" compatibility="7.3.001" expanded="true" height="82" name="Generate ID" width="90" x="179" y="34">
<parameter key="create_nominal_ids" value="false"/>
<parameter key="offset" value="0"/>
<operator activated="true" class="text:generate_extract" compatibility="7.3.000" expanded="true" height="68" name="Generate Extract" width="90" x="313" y="34">
<parameter key="source_attribute" value="html"/>
<parameter key="query_type" value="XPath"/>
<list key="string_machting_queries"/>
<parameter key="attribute_type" value="Nominal"/>
<list key="regular_expression_queries">
<parameter key="title" value=".*(title).*"/>
</list>
<list key="regular_region_queries">
<parameter key="title" value="<title>.</title>"/>
<parameter key="publish_time" value="<time class="timeformat" itemprop="datePublished".>"/>
<parameter key="paragraphs" value="<p>.</p>"/>
</list>
<list key="xpath_queries">
<parameter key="paragraphs" value="//xhtml:p/text()"/>
</list>
<list key="namespaces">
<parameter key="xhtml" value="http://www.w3.org/1999/xhtml"/>
</list>
<parameter key="ignore_CDATA" value="false"/>
<parameter key="assume_html" value="true"/>
<list key="index_queries"/>
<list key="jsonpath_queries"/>
<parameter key="value_seperator" value="; "/>
<operator activated="true" class="select_attributes" compatibility="7.3.001" expanded="true" height="82" name="Select Attributes" width="90" x="447" y="34">
<parameter key="attribute" value=""/>
<parameter key="attributes" value="paragraphs|title|time|publish_time"/>
<connect from_op="Retrieve Fussball-pages_sample" from_port="output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Generate Extract" to_port="Example Set"/>
<connect from_op="Generate Extract" from_port="Example Set" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/>
</process>
</process>
Any help is welcome
