Hi
Issue/Problem:
Can someone point me to the correct operator so that I can select the word vectors I want to use?
Thanks
Duffy
Hi Duffy,
the problem here is the metadata propagation. RM cannot predict based on the metadata which attributes will be present. What you can try is to take the meta data from the last execution. To do this try Process->Synchronize Meta Data with Real Data and run it once.
~Martin
Thanks Martin for your reply.
I understand the problem.
Your solution solved the problem.
However, before marking this thread as as "Solved", it would be preferable to avoid the long process of generating a word vector and just generate "word occurrences" for a pre-defined set of words.
For example, I have 5 words or phrases (good, great, wonderful, bad, not good) I want to know how frequently they are mentioned in the text.
What operator would I use to extract this information?
good question. I would built a dummy work vector on one text to get a word list. Afterwards you can plug this word list in your usual Process Documents to just get the 5 words you want.
