Text processing extension does not work and cannot be updated to 7.3. because of that there is no operator related to this extension and earlier models including those operators dont work as well
I am not sure what problem you are referring to, since the text processing extension has been updated to version 7.3 and it is working fine (I am currently using it for a project). It also does still have the Arabic stopword filter operator, although I haven't tested that one specifically. If you search the marketplace for "text processing" it should show up and let you intstall the latest version. I hope this helps.
