I'm trying to get my first Execute R script to read a wordlist from Wordlist to Data. I'm currently getting the error "object total not found". But "word" and "total" are two columns in the wordlist output from the above operator. And the R script construct is as per the structure given to me in RStudio. Any advice please?
<?xml version="1.0" encoding="UTF-8"?><process version="7.3.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.3.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="open_file" compatibility="7.3.001" expanded="true" height="68" name="Open File" width="90" x="45" y="34">
<parameter key="filename" value="/Users/carl/Documents/government-strategy.pdf"/>
<operator activated="true" class="text:read_document" compatibility="7.3.000" expanded="true" height="68" name="Read Document" width="90" x="179" y="34">
<parameter key="content_type" value="pdf"/>
<operator activated="true" class="text:tokenize" compatibility="7.3.000" expanded="true" height="68" name="Tokenize" width="90" x="313" y="34"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="7.3.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="447" y="34"/>
<operator activated="true" class="text:transform_cases" compatibility="7.3.000" expanded="true" height="68" name="Transform Cases" width="90" x="581" y="34"/>
<operator activated="true" class="text:filter_by_length" compatibility="7.3.000" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="715" y="34"/>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="7.3.000" expanded="true" height="68" name="Generate n-Grams (Terms)" width="90" x="849" y="34"/>
<operator activated="true" class="text:process_documents" compatibility="7.3.000" expanded="true" height="103" name="Process Documents" width="90" x="983" y="34">
<parameter key="vector_creation" value="Term Occurrences"/>
<parameter key="add_meta_information" value="false"/>
<parameter key="prune_below_absolute" value="0"/>
<parameter key="prune_above_absolute" value="10"/>
<connect from_port="document" to_port="document 1"/>
</process>
<operator activated="true" breakpoints="after" class="text:wordlist_to_data" compatibility="7.3.000" expanded="true" height="82" name="WordList to Data" width="90" x="1117" y="34"/>
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="103" name="Execute R" width="90" x="1251" y="34">
<parameter key="script" value="rm_main = function(data) { wordcloud::wordcloud(word, total, scale=c(5,0.5), max.words=100, random.order=FALSE, rot.per=0.35, use.r.layout=FALSE, colors="Dark2") }"/>
<connect from_op="Open File" from_port="file" to_op="Read Document" to_port="file"/>
<connect from_op="Read Document" from_port="output" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
<connect from_op="Generate n-Grams (Terms)" from_port="document" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="word list" to_op="WordList to Data" to_port="word list"/>
<connect from_op="WordList to Data" from_port="example set" to_op="Execute R" to_port="input 1"/>
<connect from_op="Execute R" from_port="output 1" to_port="result 1"/>
<connect from_op="Execute R" from_port="output 2" to_port="result 2"/>
</process>
</process>
