"Reading a Word Vector into Execute R"
User: "carl"
New Altair Community Member
Updated by Jocelyn
After creating a word vector, with a column of words and a column of total occurrences, what line of code would I then need to read that data into the Execute R operator?
<?xml version="1.0" encoding="UTF-8"?><process version="7.3.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.3.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="open_file" compatibility="7.3.001" expanded="true" height="68" name="Open File" width="90" x="45" y="34">
<parameter key="filename" value="/Users/carl/Documents/government-strategy.pdf"/>
<operator activated="true" class="text:read_document" compatibility="7.3.000" expanded="true" height="68" name="Read Document" width="90" x="179" y="34">
<parameter key="content_type" value="pdf"/>
<operator activated="true" class="text:tokenize" compatibility="7.3.000" expanded="true" height="68" name="Tokenize" width="90" x="313" y="34"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="7.3.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="447" y="34"/>
<operator activated="true" class="text:transform_cases" compatibility="7.3.000" expanded="true" height="68" name="Transform Cases" width="90" x="581" y="34"/>
<operator activated="true" class="text:filter_by_length" compatibility="7.3.000" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="715" y="34"/>
<operator activated="true" class="text:stem_snowball" compatibility="7.3.000" expanded="true" height="68" name="Stem (Snowball)" width="90" x="849" y="34"/>
<operator activated="true" class="text:process_documents" compatibility="7.3.000" expanded="true" height="103" name="Process Documents" width="90" x="983" y="34">
<parameter key="vector_creation" value="Term Occurrences"/>
<parameter key="add_meta_information" value="false"/>
<parameter key="prune_below_absolute" value="0"/>
<parameter key="prune_above_absolute" value="10"/>
<connect from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="103" name="Execute R" width="90" x="1117" y="34">
<parameter key="script" value="# rm_main is a mandatory function, &#10;# the number of arguments has to be the number of input ports (can be none)&#10;rm_main = function(data)&#10;{&#10; &#10; &#10; wordcloud(data, scale=c(5,0.5), max.words=100, random.order=FALSE, &#10; rot.per=0.35, use.r.layout=FALSE, colors=brewer.pal(8, “Dark2”))&#10;&#10; # connect 2 output ports to see the results&#10; return(list(data,data2))&#10;}&#10;"/>
<connect from_op="Open File" from_port="file" to_op="Read Document" to_port="file"/>
<connect from_op="Read Document" from_port="output" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Snowball)" to_port="document"/>
<connect from_op="Stem (Snowball)" from_port="document" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="example set" to_op="Execute R" to_port="input 1"/>
<connect from_op="Process Documents" from_port="word list" to_op="Execute R" to_port="input 2"/>
<connect from_op="Execute R" from_port="output 1" to_port="result 1"/>
<connect from_op="Execute R" from_port="output 2" to_port="result 2"/>
</process>
</process>
